Hi all,
I've been through the FAQ Emporium, the forum rules, and many threads on here. Now I'm looking to hopefully receive some more individualized help.
The car is a 2010 Corolla S Manual. It is currently stock, non JBL radio.
The planned audio- I'm selling off my kicker zx350.4 currently on eBay in favor of purchasing an Alpine PDX-5 to mount under one of the front seats. The speakers I already own- a set of Pioneer D series 6.5 components in front and Polk DB691 for rear. I'm planning on buying a shallow mount sub once I have the amp, and mounting that in the trunk- possibly the JL 13". I already have everything ripped out of the old car and in my closet waiting.
I currently own a Pioneer Avic-f700bt. Great unit once it has firmware 3.0, but I'd rather create my own now that I've seen everything in action. I actually bought 2 of them when Circuit City was going under for $250 a piece. The second is in the girlfriend's car.
I'll probably install this temporarily while I build and test the CarPC, then sell to recoup some of my costs.
I need to buy:
Intel BOXD945GCLF2 (i want tv out in case of headrest monitors if i still own this when we have kids)
Corsair 2GB ddr667
BU-353 GPS Antenna
M2-ATX??? I realize the DSATX is better, but twice as good? (2x$)?
Pioneer cd-vm1 (their gps unit mic, (20$ crutchfield) have to test compatibility with PC)
Xenarc 705TSV (seems like price/performance bang for buck, also easiest to dash mold without removing bezel)
Centrafuse Navi (current version now, then 3.0 free when it releases)
I already own:
Asus Bluetooth Mini-USB
USB Wifi-N
160GB Sata 2.5" Seagate
Windows 7 RC 64bit (could also use XP Pro 32bit)
Double Din Dashkit/harness (its in the mail...)
reverse camera
I might get:
USB sound card like the Turtle Beach SRM, open to suggestions
Slot load DVD/CD (don't really use CDs, we'll see how getting the screen to fit goes)
Slim Keyboard
which would fit nice in my upper glove box
Wired OBD-II (eventually)
Does this seem about right, equipment wise, considering what I'd like to do with it:
-Bluetooth Sync with my Blackberry Curve, make/receive calls using PC/Speakers
-Store/play all my music (30 or 40GB)
-Wireless to network at home so I don't have to remove it for changes.
-GPS Navigation
-Eventually OBD-II
My questions are mainly about power, as I wasn't positive I understood the Power FAQ. The M2-atx should have plenty of raw wattage for my needs, but I'm not sure how it all gets wired up in conjunction with my amp. Is this correct-
Battery->Inline 4gauge fuse->4guage cable->Power Distro block (grounded to seatbolt), then split to M2-ATX with 12ga and to PDX-5 with 4ga?
How can I wire the screen to the M2, is there a cable adapter kit to buy? Especially since it will have to run from the front dash to under a seat.
Quote:
On a molex conenctor this is the Yellow wire (12V +ve) and you also want to use the adjacent black wire for -ve.
If you power your monitor in this way you do not have to use the 12V regualtor that comes with it - doing so as well may introduce noise and also cause your screen to be dimmer due to a voltage drop. It is also one more thing to go wrong.
Easy enough, but how does it connect to the Xenarc wiring? Do I have to void my warranty to wire it this way? How can I wire it if I don't want to void my warranty or have a cig lighter adapter sticking out?
Finally, and I ask this without research because it just came to me, do I utilize the radio harness at all? Unless I'm wiring into it for power I don't know why I'd need it? I'll be running fresh monster cable for the speakers...
Thanks for reading through!
