Go Back   MP3Car.com > Mp3Car Technical > Newbie > Newbie - Proposed setup
Old 09-16-2009, 06:02 PM   #1
naiku is an unknown quantity at this point
How is this set up so far?
I am slowly putting together a list of components I need for the system for my A4 Avant, and so far have the following:
GIGABYTE GA-73PVM-S2H Micro ATX Intel Motherboard
Intel Celeron E3300 Wolfdale 2.5GHz 1MB L2 Cache LGA 775 65W Dual-Core Processor
Kingston 2GB (2 x 1GB) DDR2 800
Western Digital Scorpio Black 320GB 2.5" SATA 3.0Gb/s Internal Notebook Hard Drive
LITE-ON Slot Load Slim CD/DVD Burner Black SATA Model DL-8ATS
Cirago BTA-3210 Micro Bluetooth Dongle support Bluetooth 2.1
TRENDnet TEW-424UB USB 2.0 Wireless Adapter
BU-353 Weather-proof GPS Receiver
M2-ATX 160 Watt Intelligent Power Supply
Still trying to decide upon a screen, I had hoped a 10" would fit, but think I am going to be limited to an 8". Also not sure on FM/HD/Satellite radio yet.
Ultimate goal is going to be for a mid-end SQ based system, possibly with 5.1, and want the ability to run an active set up and use time alignment/processing etc.
Any comments? Am I on the right track, or should I scrap the list and start again?
Thanks.
naiku is offline   Reply With Quote
Old 09-16-2009, 06:35 PM   #2
kross is an unknown quantity at this point
That motherboard has some of the best onboard audio quality around, so that's a good choice, assuming you don't mind the larger form factor of micro-ATX instead of mini-ITX. It has 7.1 audio, which is enough channels to do a 3-way active setup, plus subwoofer channel.
The Pentium E5300 has better specs, and is only a couple dollars more.
kross is offline   Reply With Quote
Old 09-16-2009, 10:00 PM   #3
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
looks like you are on the right track, for anything more than a factory sound system, i would recomend a addon sound card-- pci/pcie would be better than usb/firewire, but usb/fire wire will work if you don't have the space.
look in the car audio sections for ideas on audio processing-- there are many different solutions.
soundman98 is offline   Reply With Quote
Old 09-17-2009, 08:47 AM   #4
Thanks both, I am not sure on the exact dimensions yet, but pretty sure I have plenty of space to work with micro-ATX (I think I saw the dimensions of that motherboard as around 9" x 9", which should hopefully fit) and a pci/pcie sound card. I am hoping to mount the PC in the right side of the trunk, currently in that space is a Bose Amp, Sub etc. When I install the carputer I plan to remove all of the Bose system.
Is the Creative Sound Blaster Audigy SE 7.1 Channels PCI Interface Sound Card a recommended sound card? Heading over to the car audio sections forum now to do some more reading.... oh how I wish I had the $$$ to go out and order all this today!
Recommend a set of 6.5" components... hd54321 Car Audio 3 10-22-2005 01:55 PM
2 sub set up GeeZeR Car Audio 2 07-30-2005 01:26 AM
How to set Freedrive directions volume Phythorian Road Runner 2 07-28-2005 06:35 AM
need help with my set CorollaVerso'04 Newbie 0 04-18-2004 04:32 PM
LCD randomly changing set? mad man LCD/Display 3 12-14-2003 08:33 PM
