10-01-2009, 12:58 AM
#1
What does everyone think of this setup?
This is just the main part of the brain for now but what do you all think?
JetWay JNC62K-LF AM2+/AM2 NVIDIA GeForce 8200 HDMI Mini-ITX Motherboard
AMD Athlon 64 1640 2.7GHz 45w CPU
2GB Mushkin 800 MHz DDR2 PC-6400 SDRAM
JetWay JNC62K-LF AM2+/AM2 NVIDIA GeForce 8200 Mini ITX Motherboard SPECS:
Brand JetWay
Model JNC62K-LF
Supported CPU
CPU Socket Type AM2+/AM2
CPU Type Phenom / Athlon 64 X2 / Athlon 64 / Sempron
FSB 2600MHz Hyper Transport (5200 MT/s)
Chipsets
North Bridge NVIDIA GeForce 8200
Memory
Number of Memory Slots 1×240pin
Memory Standard DDR2 800
Maximum Memory Supported 2GB
Expansion Slots
PCI Slots 1
Storage Devices
PATA 1 x ATA100 2 Dev. Max
SATA 3Gb/s 4
SATA RAID 0/1/0+1/5/JBOD
Onboard Video
Onboard Video Chipset NVIDIA GeForce 8 series
Onboard Audio
Audio Chipset Realtek ALC883
Audio Channels 8 Channels
Onboard LAN
LAN Chipset Realtek 8211B
Second LAN Chipset Realtek 8111C
Max LAN Speed Dual 10/100/1000Mbps
Rear Panel Ports
PS/2 1
COM 2
Video Ports D-Sub + DVI
USB 6 x USB 2.0
Audio Ports 6 Ports
Onboard USB
Onboard USB 2 x USB Connectors @ 480 Mbit/s for 4 USB 2.0 Ports
Physical Spec
Form Factor Mini ITX
Dimensions 6.7" x 6.7"
Power Pin 20 Pin
Features
Features 2 x DB-9 RS232 Port
Packaging
Package Contents JNC62K-LF
Driver Disk
User Manual
Rear I/O Panel Shield
IDE/PATA Cable
SATA Cable
DVI to HDMI Adapter
CPU Cooler with Fan
AMD Athlon 64 LE-1640 CPU SPECS:
Brand AMD
Processors Type Desktop
Series Athlon 64
Model ADH1640DHBOX
CPU Socket Type
CPU Socket Type Socket AM2
Tech Spec
Core Orleans
Multi-Core Single-Core
Name Athlon 64 1640
Operating Frequency 2.7GHz
Hyper Transports 2000MHz
L1 Cache 128KB
L2 Cache 1MB
Manufacturing Tech 65 nm
64 bit Support Yes
Hyper-Transport Support Yes
Virtualization Technology Support No
Multimedia Instruction MMX, SSE, SSE2, SSE3, 3DNOW! Professional
Voltage 1.25/1.35/1.40V
Thermal Design Power 45W
Cooling Device Heatsink and Fan included
Manufacturer Warranty
Parts 3 years limited
Labor 3 years limited
2GB DDR2 PC-6400 SDRAM SPECS:
Brand mushkin
Model 991580
Type 240-Pin DDR2 SDRAM
Tech Spec
Capacity 2GB
Speed DDR2 800 (PC2 6400)
Cas Latency 4
Timing 4-4-4-12
Voltage 2.0V - 2.1V
Heat Spreader Yes
Parts Lifetime limited
Labor Lifetime limited
10-01-2009, 02:24 PM
#2
I have two of those motherboards. I like them a lot. I have problems with a particular USB device on one of the motherboards with Windows. Same device on another motherboard of the same model under Linux works fine. The Windows one is also using an M2-ATX, and the Linux one a desktop PSU. So I'm still not sure if it's a driver issue or a power issue (it's a high-power USB device). See http://www.mp3car.com/vbulletin/revi...2k-review.html for details.
As for the CPU, I assume you're recycling it from an older system? If so, fine. Otherwise, if you're buying it, you can get an Athlon II 2.8 GHz dual-core for $63.
Hope this helps!
-- Kevin
10-01-2009, 05:39 PM
#3
Everything is brand new, the reason I chose that CPU is, well, I didn't. It all comes in one package and I can get a really good deal on it. I just want to make sure it will work for my application.
I read all about the USB problems which makes me hesitant but that thread makes it look like it's a power issue, not a mobo issue based on some other posts. I don't have any high drain USB devices but I do have lots of devices (Sirius, GPS, TC, OBDII, etc).
Is the single core sufficient for a carpc? The biggest drain I can think of is maybe GPS + DVD running with RR at the same time.
10-01-2009, 06:36 PM
#4
I had the same motherboard and cpu in my previous installation and a 2 giga Kingston ram. It was very flashy with a lot programs on the hard drive. The only thing you have to be careful is to keep it cold. The 1640 produce a lot of heat.
10-01-2009, 06:55 PM
#5
Define flashy. Do you mean it was "stuttering" while performing tasks?
Would keeping it cool in +40C ambient be too difficult to be worth it?
10-01-2009, 07:25 PM
#6
That's pretty toasty. Make sure whatever case you put it in, it has lots of airflow. Cases like the VoomPC and MoCoSo cases probably wouldn't have enough airflow through them to keep it cool with +40C ambient temperatures.
10-01-2009, 08:45 PM
#7
I was planning on building my own case going off of blk02si's drawings. I have an 05 F-150 so his exact dimensions would fit perfectly. I'm wondering if the -30C weather would be a problem with that type of case though...
10-01-2009, 10:54 PM
#8
You have temperatures from -30 to +40C? Wow. Where do you live?
If I recall, hard drives won't operate at that low temperature. I think SSD's do, though.
10-01-2009, 11:26 PM
#9
I live in a semi-arid desert (+40)...in Canada (-30).
Weather.ca says:
Max Temp: 40.4 °C
Max Temp.Date: Jul.23 2006
Min temp: -27.7 °C
Min Temp. Date: Jan.15 2005
Anyways, is my only choice an SDD? Is this CPU too hot for me?
10-02-2009, 03:24 AM
#10
I mean that with that cpu the pc was fast. If you planing to make your own case with good airflow then you don't have any problem
10-02-2009, 07:13 AM
#11
I am using the same motherboard. only issue is i am not getting VGA out from DVI-I port. so no dual display till date
10-02-2009, 05:28 PM
#12
What's the most anyone would pay for that setup?
10-05-2009, 03:10 PM
#13
For the setup in the first post? Well, it isn't really a complete setup, but you can get that MB for $130 and memory for $20 at Newegg. That CPU isn't available any more. They have a Sempron 2.7 GHz single core, 45 Watt, for $37. So the most I would pay would be $187 (USD).
10-05-2009, 03:20 PM
#14
If I can get it for <$100 should I go for it or is there better for that price?
10-05-2009, 03:41 PM
#15
For <$100 including shipping is a great price if new, with warranty. If you're getting it used, with no warranty, then the price is still good, but not great.
| Thread Tools |
| Display Modes |
Linear Mode
