Go Back   MP3Car.com > Mp3Car Technical > Newbie > Newbie - Proposed setup
Old 11-06-2009, 11:47 AM   #1
Enlighter is an unknown quantity at this point
Advice/Help for a First Timer...
So I have the base set up for a new system in my car.
I am still working on the pc itself, but I have some questions before I complete that build.
Mainly, do I need a sound card, or can I get away with the on board audio of this motherboard.
ZOTAC Motherboard
Other then that my system consists of the following...
JL W1v 10" Sub
Alpine PDX-5 75w x 4 and 300w x 1 amp
Tsunami Lite Wave Capacitor
JL TR050-CT1/2" Tweaters (possibly two sets one for up high one for the floor boxes)
JL TR600-CXi 6 1/2" 2-way speakers
JL TR525-CXi 5 1/4" 2-way speakers
What I am considering in addition to this, depending on the requirements, is adding 2 more 6" speakers wedged in the front right and front left corners of the floor area in the passenger and drivers side of the car. In addition to the 6"ers I would add 2 more tweeters.
So in total up front, there would be the door speakers, the floor boxes, and then the tweeters up high.
In the back there would be door speakers, and speakers in the very rear on the roof and then the sub mounted in the back next to the right rear window.
All of this would be attached to a car pc somehow, no idea how it would need to be set up, wether through a sound card, or just the built in.
Also no idea how the wiring of it all would need to be laid out/fused.
I will be running it right from the red top under the hood, also have no idea how to best do this. I want to avoid splicing into lines that are already there AT ALL COSTS.
Any advice is greatly appreciated.
Enlighter is offline   Reply With Quote
Old 11-06-2009, 12:05 PM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
look here for some generic info on connecting a carputer to a sound system:
http://www.mp3car.com/vbulletin/advfaq.php
other than that, it is really personal preferance wheather the onboard sound is good enough for you. it is usually at least adequate(it emits sound), and most do not have a problem with it. you can always add a soundcard in later, so try the onboard first, and if it is too poor for your tastes, upgrade.
soundman98 is offline   Reply With Quote
Old 11-06-2009, 12:12 PM   #3
Mp3Car Staff
Heather's Avatar
Heather is a jewel in the roughHeather is a jewel in the roughHeather is a jewel in the rough
moving to the newbie section, under proposed setups.
http://www.mp3car.com/vbulletin/newbie-proposed-setup/
Heather is offline   Reply With Quote
Old 11-06-2009, 01:13 PM   #4
Heather,
Thanks for the move.
Soundman, thanks for the general advice, I figured that much, I am more curious about how to set the entire thing up. Wiring wise. Maybe a diagram would help me, no idea where to begin with that though.
Old 11-06-2009, 01:36 PM   #5
soundman98's Avatar
its all explained in the adv. faq(link at the top, in the middle):
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
unlike other sites, the faq here is really helpfull
Old 11-06-2009, 02:38 PM   #6
reading it over now, have some crazy thoughts in mind.
Such as using this
Touch Book
Instead of a full on pc with touch panel...
No idea how I'd get the music off it to play through the speakers I am setting up in the car though...
Old 11-09-2009, 04:02 PM   #7
kross is an unknown quantity at this point
As long as the computer has some type of audio out jacks (such as the usual 1/8" headphone jacks), then this will get the sound to the speakers:
kross is offline   Reply With Quote
Automatic 555 timer, delay off locked Hardware Development 8 08-04-2009 08:18 PM
Menu and Timer help 2poor4mods Road Runner 7 06-23-2009 07:49 PM
12 Volt Timer For Computer kozmo Power Supplies 20 02-18-2007 11:02 AM
555 Timer Problem.. Need it To Trigger when key removed fire Power Supplies 19 07-27-2006 04:44 AM
Timer Circuit Fox_Mulder General Hardware Discussion 3 11-04-2005 10:47 AM
