The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 03-30-2007, 05:39 PM   #1
My Photos: (0)
400 w power inverter
Hello
I just picked up a 400W power inverter by jensen.
I have.. amp/sub combo that is getting power from the battery..
The carpc is going to get the power from battery.. and if i connect the inverter to the battery... Will that be too much drain ffrom battery.. or if i get a high end battery that would work ?
Also i am guessing connecting the inverter to batterry or cigarette lighter would mean same drain.
I am only using inverter to power up 15" lcd monitor.
Please let me know.
thanks
Tanmay
tanners is offline   Reply With Quote
Sponsored Links
Old 03-30-2007, 05:53 PM   #2
Takes it in the Rear
kevinlekiller's CarPC Specs
kevinlekiller's Avatar
My Photos: (0)
The battery is mainly used in a car to start the car, the alternator supplies the current when the car is running, and it keeps the battery charged for when you need to start it. A good reason to put in a new battery is if you run the sound system and pc when the car is not running , then the drain will be on the battery. The question you should ask yourself is if you should replace the alternator, and the battery if you run the pc for long periods of time without starting the engine.
The difference between wiring to the cigarette lighter port and the battery is huge , the cigarette lighter port can carry a certain amount of current , due to the size of the wires and fuse ( a cigarette lighter port can carry usually between 5 - 30 amps of current ).
A 400w inverter will draw 40+ amps at max load. ( 400w is the output power , but a inverter is not efficient ( loss of energy ( heat mainly ). So it can take roughly 500+ watts at the input wich is ( 500/12) 40 amps , usually a cig lighter port is 20 amps ( check the fuse ).
But Im not saying its going to draw at max load ( since you are gonna use a lcd wich is roughly 80-150watts )
kevinlekiller is offline   Reply With Quote
Old 03-31-2007, 04:00 PM   #3
john05srt4's Avatar
Vehicle: 2008 Scion xB
My Photos: (0)
Wire the inverter into where your amps are drawing power. It will work fine.
Just remember you cant sit with the stereo and LCD on for long witout the car running.
My Accord CarPC
john05srt4 is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
Will the Power Inverter be enough? kbkid Power Supplies 7 11-09-2006 07:16 AM
Question about inverter and normal pc power supply bns2000 Power Supplies 3 10-16-2005 03:49 AM
how can I wire up power inverter to secondary battery, but turn on when car starts? CrazyModGSR Power Supplies 4 10-29-2004 08:10 AM
Simple Idea for keeping power to inverter while cranking.... syclone477 Power Supplies 1 03-23-2004 09:03 AM
Sponsored Links
Ad Management by RedTyger
