The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-01-2007, 02:46 PM   #1
My Photos: (0)
MP3 Player to GM Factory Radio
Hello to all.
This is my very first post in these forums, so you have my apologies if I pull a "n00b" and say something completely demented.
My goals aren't nearly as elaborate as installing a PC into my truck. All I'm looking to do is hook up my mp3 player directly to the factory radio vs. using the FM Transmitter that I wasted $40 on.
What I've Got
-Creative Zen Vision:M mp3 Player
-2002 Chevrolet S10 w/Ext. Cab and Factory Radio
What I know:
The front of the radio has the RDS logo stamped on it. I took apart the dash and took a look at the factory radio to check for an auxiliary port. The radio is from Delphi Delco Electronics, manufactured 4/10/02. The radio has a 12 pin port on the back: 2 rows of pins, 6 pins per row.
The research I've done has lead me to a seemingly promising solution, namely a PIE connector that can plug into an aux port and, via a RCA-to-3.5mm cable, connect the mp3 player to the radio. *But*, from the reading I've done thus far, it seems that not all 2002 S10s were given the same radios (some were given radios with a 9-pin aux port on the back, and then I'm guessing that based on what I have, some were given radios with a 12-pin aux port).
The part I'm looking at is this:
http://www.cardomain.com/item/PIEGM12AUXV2
GM12-AUXv2 - GM12-AUXv2 2000-07 GM "Class-II" Auxiliary Audio Input Adapter - Accessories - Precision Interface - Discount Car Stereo.com - Detail
However, the sites have conflicting statements about whether it will work on a 2002 S10 - cardomain says 'yay' and discountcarstereo says 'nay', yet they both seem to be the same part...
What I'm Trying to Find Out
- Basically just trying to figure out what makes a radio a "class II RDS" radio and whether I have one.
- Trying to figure whether a converter like this will require me to tap in to the electrical system of the truck or if it would just be a straight plug n' play.
- Any wisdom/advice that can be passed on from those more experienced than I.
Many thanks to those who take the time to read through this and give your thoughts.
Cheers.
thewams is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
mobiBLU DAPs at walmart.com-World's smallest MP3 player. toomwatson General MP3Car Discussion 2 11-01-2005 03:46 AM
Installing computer w/ 2000 GM factory stereo-how to connect SpkTheD General Hardware Discussion 8 05-09-2005 08:05 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
