Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-03-2007, 08:28 PM   #1
FAQ new to the world of carputers and about to ask some stupid questions
hello all,
I was hoping someone here might be able to help me.
1. Where can i get Destinator 3 SDK from? i cant seem to find it anywhere, im planning on using it with Map Monkey embedded in Road Runner.
2. mp3car's store sells a convertible friendly modified 7" screen. does this actually work? can you read everything even with direct sunlight? any pics or vids of it working would help.
3. Which usb GPS module should i be using? i need to mount it on my dash since i have a convertible.
4. can i integrate phonecontrol.net with road runner? if so how do i do this? so that it runs embedded in the road runner skin. i will be using bluetooth as the connection method.
5. i want an actual volume knob rather than jus the touchscreen controls. can i buy a usb one? any help in this matter would def be appreciated.
6. i have quite a complicated audio set up at the moment. 2 subs in the boot, 2 6x9s in the rear quarter panels 2 components in the front. all run of 3 amps (one for the front, one for the back, and one for the subs). can i simply connect the relevant outputs from the pc sound card to the rca inputs on the amplifier?
7. I am going to fit a digital tv card in the carpc, can anyone recommend a good external aerial that will pick up signal even on the go? i've got a bmw e36 convertible with the beesting aerial on the drivers side (uk, so right). i dont mind fixing a similar looking aerial to the other side, hence the choice for an external one.
8. I have an AV switch in the car which allowed the dvd player and ps2 to be viewed on either screen indepently. its a 4 in 3 out av switch, can i connect the car pc as one of the inputs as well as running the vga (dsub) to the main touch screen at the front?
lol, i know its a lot to ask, but im sure there will be more as the project gets underway.
thanks,
Amit K
amk136 is offline   Reply With Quote
Advertisement Sponsored links
Old 04-03-2007, 09:39 PM   #2
_
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 04-03-2007, 10:07 PM   #3
DodgeCummins's Avatar
RedGTiVR6...you nailed it.
I will do the standard...
Pretty much everything you asked had a keyword within the line that you could put into the search window and come up with a group of results.
It may sound obvious...but when we have a wonderful library of information in this message board, all itemized by topic, that you desire to have duplicated right here...it seems like a terrible waste of space and bandwidth.
Now stand by for the flamethrowers.
current projects
DodgeCummins is offline   Reply With Quote
Old 04-03-2007, 10:55 PM   #4
Fusion Brain Creator
2k1Toaster's Avatar
Nameeri's thread has a video. Yes it works. Why would they sell it if it doesn't work?
We wont do your shopping. Search with "SirfIII".
have you searched at all? But yes. Find out yourself. It already does. That is the best way.
Look in the store. Haptic encoder.
Yes.
No. PC TV tuners dont work while moving. They suck. As with USB radio dongles. The HQCT is the best for radio, but only North American radio. In the UK, you are pretty much out of luck unless you buy a local HU and run it for radio.
I don't know what you mean. You want to display your computer's screen cloned on both the RCA connection and a seperate vga monitor? Yes you can. Search.
As red has so elegantly put it, this is a flame thread waiting to happen.
You really need to search before you post. From your questions I assume you didn't. You have used your 1 free n00b post. No more.
2k1Toaster is online now   Reply With Quote
Old 04-03-2007, 11:13 PM   #5
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by RedGTiVR6 View Post
Must I just say how gorgeous you are looking today Red?
Done something different with your hair?
Enforcer is offline   Reply With Quote
Old 04-04-2007, 12:25 AM   #6
GizmoQ's Avatar
Its been a long time since I've had an all out belly laugh, thanx
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 04-04-2007, 07:15 AM   #7
Neither darque nor pervert
DarquePervert's Avatar
Red:
So you were posting pics of bunny suits while we were fabricating outside?!?!?
This is some funny ****!
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-04-2007, 07:23 AM   #8
_
I just couldn't hold back this time.
There used to be a : putsonflamesuit: smiley out there, but I couldn't find it.
Jan Bennett
Old 04-04-2007, 07:46 AM   #9
Actually, looking at the time, this is about when we were cleaning up.
And you know I'm just bustin' your chops.
Kudos for Badger-man for the very detailed post. Very helpful.
My Worklog
Old 04-04-2007, 10:37 AM   #10
thank you all for your help, i shall get up off my fat ***, do the research, and the post the burnt images of my car as i attempt to build a carputer...
adios
Amit K
Old 04-04-2007, 01:19 PM   #11
lol good to see he has a sense of humor!
Nice one red
Scott Hancock
www.hdtechnology.com.au
HDTechnology is offline   Reply With Quote
Old 04-05-2007, 08:43 AM   #12
Fellas & Ladies....
I Need Some Help. I Am Still At The Software Testing Stage. I Have Managed To Get Phonecontrol.net To Recognise My Phone, I Can Make And Receive Calls While In Standalone Mode. What Is The Next Step? How Do I Get It To Work In Road Runner, I Am Using The Simplistique Bmw Skin That Lloyd Designed.
Also, Freedrive.co.uk Is The Site For The Alternative To Destinator Sdk Correct? I Cant Seem To Get Onto It.
Amit K
Old 04-05-2007, 11:39 AM   #13
_
You need to ask your question about road runner and phone control in the road runner forum.
Jan Bennett
