Quote: Originally Posted by
DodgeCummins
You might want to search in the M2-ATX area for more detailed info on how much power it can actually put out.
Look at the power FAQ and you will find some links to power calculators.
I can tell you now you are going to pull too much and blow the M2. And when an M2 goes, it takes hostages with it usually the mobo/cpu combo. Either downgrade the CPU to a mobile version (via or mobile amd, or pentium m, or duo core).
You chose a SATA drive. SATA has horrible connectors. In a desktop they suck, in a car environment they suck harder. They don't lock, or mate well. So it will wiggle loose as everything in a car does, and who knows what will happen. IDE is a good format, and you wont see any gain with SATA over IDE.
