Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-04-2007, 03:09 PM   #1
accord '04 wiring help
i know this is a site for audio and video stuff but i wanted to install, just as a simple project, some led's or something in the footwell and i dont know where to tap the power from and stuff, so i figured it would be along the same lines as a audio or video unit mod. If anyone has done this or just knows where i can find the wires to do it in the car that would be great. thanks
dfresh1121 is offline   Reply With Quote
Old 04-04-2007, 03:14 PM   #2
XC-C30's Avatar
good guess.... but unfortunatly.... well.... wrong.
This site is about car-pc's not video or audio specificly.....
edit: My special thanks go out to our typical badger who has succeeded in putting a smile on my face:lol thanks man
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 04-04-2007, 03:19 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
A bit too for me, but whatever...
If you mean powering it, then sorta.
Look for a wiring diagram specific to your car. That is where you can find +12v constant and +12v switched. Ground is all the metal in your car.
LED's need like 2v. Your car gives 12. You need something inbetween. Also, if the LED is the only load on the circuit, it wont be bright for very long. It will burn out. You need something to control that. Both can be done with a simple device that transfers the electronic gnomes to magical heat waves.
Old 04-04-2007, 03:20 PM   #4
XC-C30's Avatar
depends on the LEDs even. Some are only 1.3volt....
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 04-04-2007, 03:23 PM   #5
2k1Toaster's Avatar
And the super-brights are like 5v. But the 3mm bulbs are usually pretty low, and will work on a range. Either way the magic mystery part behind door #3 is what you need.
Old 04-04-2007, 03:25 PM   #6
i planned on using some type of switch to regulate
Old 04-04-2007, 08:43 PM   #7
I have an 03 accord our power supply is located in the same spot since we both have a 7th gen. If you look underneath your steering wheel on the floorboard to the left you will see a panel. Pull that panel out. After you slide it out you will see a bunch of fuses. Find a fuse that isnt being used. If you are driving a coupe plug it into back power windows.
If you have any problems feel free to PM me.
oswhiteboy is offline   Reply With Quote
Old 04-05-2007, 08:40 AM   #8
john05srt4's Avatar
Try
http://www.v6performance.net/forums/index.php?
or
http://gen7accord.com/
or
http://www.driveaccord.net/
my main question is how much power will you need. Usually its a better idea to run a new power cable straight from the battery to you interior then tap off that for your POWER needs.
Also a switch will not "regulate" your voltage of power from 12v.
My Accord CarPC
john05srt4 is offline   Reply With Quote
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
04 accord radio problem DADAMS09 Car Audio 2 12-11-2006 06:06 PM
04 accord nguyenpd Car Audio 1 06-17-2006 10:26 AM
FS: 7" VGA Module or 04 accord bezel calvincbr Classified Archive 4 02-20-2006 07:10 PM
04 accord lcd fallnangel LCD/Display 3 09-16-2004 06:20 PM
