Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-04-2007, 03:36 PM   #1
Help me decide what to do with my slot. . .
Ok, no flames. This is the newb section.
I have one PCI slot open on the Via motherboard I bought and I want to know opinions on the best way to use it. I have 3 thoughts in my mind, which is 3 more than normal.
1. Video
2. Audio
3. PCI to USB converter.
First the video, I don't know that I'll need rockin' video in the car from what I've heard. It sounds like the onboard video should be enough.
Audio would be good, because I kind of want the 5.1 surround sound thing happening. The only problems I see are that using a card like that could be more expensive than a USB Sound Blaster doohickey. Plus the Sound Blaster will provided a master volume control for the computer, which I like.
PCI to USB might be good since everything seems to be USB these days. But I know nothing about them. Do they work? Are they troublesome? Also, I think I might just have enough with the ones that come on the board.
So don't be shy, pipe up and make suggestions, correct any info above I may have wrong or just tell me to leave the stupid slot blank.
Thanks.
Profozone is offline   Reply With Quote
Old 04-04-2007, 04:01 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
My suggestion is to use nothing in your PCI slot until you determine a need.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-04-2007, 04:18 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
Bad thread title!
And what DP said. why put it in, if you don't need it?
Old 04-04-2007, 04:57 PM   #4
Quote: Originally Posted by 2k1Toaster View Post
Bad thread title!
Thank goodness I'm not the only pervert around here!
"It's a blessing . . . and a curse."
Siezmik is offline   Reply With Quote
Old 04-04-2007, 06:40 PM   #5
When I designed my carputer, I took out all the useless PCI cards. Saves power. PCI>USB would be useful only if your current motherboard does not have usb 2.0.
nobb is offline   Reply With Quote
Old 04-04-2007, 09:39 PM   #6
LOL! Didn't realize when I titled it how is sounded. Too funny.
Ok, I can live without sticking something in there. That was actually plan A.
Thanks for the opinions. . . you dirty minded little websurfers!
Old 04-04-2007, 09:47 PM   #7
In general every time I tried to fill all the holes just 'cause they were there, I regretted it. Later on I found need for some other periferals and purchased them, replacing the space fillers, and retro-actively wasted money. With Moore's law and the like, by the time you discover the need for the 'slot-filler' the products available will be better than the one you would have originally purchased anyway, even if you predicted the right type of device. Just my $.02.
h3rk is offline   Reply With Quote
Old 04-05-2007, 09:39 PM   #8
DodgeCummins's Avatar
Do you have a mini-itx motherboard that only has one slot?
Or do you have a motherboard that already has a bunch of stuff plugged in.
If it is the mini-itx mobo...VIA makes a 2 slot PCI adapter for it. I am using it to run a graphics card and wireless card.
If is other...I have used a USB sound card...it worked just fine...but not as good as a nice PCI card would...but I am using onboard sound now...and with most music I can't tell the difference.
You don't need a PCI ethernet card...use USB for that.
I guess your mobo doesn't have onboard USB either...it must be an old or interesting mobo...yes you can add a pci usb card...I have about 5 usb devices I run on my computer.
Tell us more about the mobo.
current projects
DodgeCummins is offline   Reply With Quote
Hacking Head Unit CD with CD/DVD-ROM slot load drive? pktloss Hardware Development 7 03-25-2006 09:42 PM
lcd mount into weird slot burnhamd Fabrication 0 08-27-2005 09:08 PM
Slimline slot dvd-rom, now $66 at Newegg mykolJay General Hardware Discussion 5 09-09-2004 02:08 PM
Problem with connecting 2 Type II pcmcia cards to a Type III slot. AVmobile General Hardware Discussion 0 01-28-2004 09:14 PM
*one* bad pci slot? also, bad NIC? InFix General Hardware Discussion 7 11-27-2002 11:49 PM
