Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-20-2007, 12:54 PM   #1
sporty_drew's Avatar
Slim Line Type Adapter
I've picked up a Slim Line Type CDROM/DVDROM/CDRW Adapter
for my slot load dvd player and i'll be using an ide to usb adapter off of that.
I'm just wondering if i need to use the +12, neg, neg +5 on the adapter or if i can just give it +5 and a neg since the drive says it runs on 5 volts. I don't want to run more wires than i have to since these will be ran to the front of my car. Thanks, Drew
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
sporty_drew is offline   Reply With Quote
Old 06-20-2007, 02:45 PM   #2
no need for the +12 but you might as well cause don't you have to power other things back there?
guizai is offline   Reply With Quote
Old 06-20-2007, 11:32 PM   #3
nah i'm pulling the power from the computer which is in the hatch while the slot load is going to be in the sunvisor. so i need about an 18 foot extension so i only need the 5 volt and a ground?
Old 06-21-2007, 12:55 AM   #4
_
I'd be weary of running your drive like this. It seems that the cable won't be very secure at all.
Have you thought about using a case instead? It seems it would be much more secure.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 06-21-2007, 01:07 AM   #5
i won't have room for a case, i can always use some sort of adhesive. It's the best i can come up with for the space i have. But i wanted to make sure i only needed 5 volts to run the drive and not the 12 volt rail also.
Old 06-22-2007, 02:33 PM   #6
crooper's Avatar
I'm using this exact setup for my ATAPI DVD drive in my dash. Works awesome. And if your ATAPI-to-IDE adapter is the same as mine, you'll need a floppy power connector. Grab one from an old power supply. I use a 3 prong extension cable to run power from my carpc in my trunk to my dash. Just hook up each wire to 12v, 5v, and ground. See the pic. One end is a 4-wire standard molex, other is the floppy connector and my Xenarc power wire. My avatar shows the DVD drive in the pocket underneath my screen.
crooper is offline   Reply With Quote
Old 06-22-2007, 07:12 PM   #7
crooper's Avatar
As for whether you need 12v, just check the drive specs, it should say on its label how much power from what rail it requires. Like this spare laptop hard drive I have here says "DC+5V 0.7A". If it doesn't say 12v, then it doesn't need it.
Old 06-23-2007, 02:56 PM   #8
i got it working and will post pictures later tonight. the drive only says 5 volts but for some reason is wont work without the 12 volt rail hooked up also. Thanks alot guys.
Slim drive adapter sticks out skippy911 General Hardware Discussion 5 05-09-2005 09:59 PM
FS: Toshiba Slim Line External CDRW/DVD (USB) mangina24 Classified Archive 6 03-28-2005 10:37 PM
Where can I find an adapter for a slim, slot-loading drive Slimline General Hardware Discussion 2 02-08-2005 10:52 PM
F/S CD-R/RW/DVD Rom Drive Slim Line NightHunter Classified Archive 10 01-26-2004 07:49 AM
slim slot adapter (Updating) SonicCobra03 General Hardware Discussion 6 09-27-2003 08:55 AM
