The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 06-20-2007, 11:25 PM   #1
Vehicle: 2002 Buick Rendezvous
My Photos: (0)
2 Single DIN units in a Double DIN mount
I'm not familiar enough with DIN to know if this is actually possible. What I'm thinking of doing, is getting a retractable single din LCD, and mounting it in ht etop portion of the double DIN mount, with my Kenwood Excelon x589 in the lower half. This way, I could avoid buying an amp, and maybe have an easier time with my audio install.
My original plan was to mount an 8" LCD in the double DIN location, and run the PC to that and an AMP, for audio.
ANy thoughts on what would work better, or if the double DIN idea would even be possible? Thanks!
Progress: 0% (Planning phase)
Dondro is offline   Reply With Quote
Sponsored Links
Old 06-21-2007, 06:43 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Two DIN units will fit in a double-DIN opening.
An 8" monitor will not fit without modification to the bezel of the opening. A 7" screen will fit pretty closely. You will likely need to do some finishing to the opening to make it look clean & neat.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-21-2007, 08:28 AM   #3
sama's CarPC Specs
sama's Avatar
Vehicle: BMW 850CSi
My Photos: (0)
an8" widescreen would fit nicely
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 06-21-2007, 09:16 AM   #4
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
I've fit an 8" 4:3 screen but I've had to modify the face of the screen to be able to do this in the VW.
Running two single din units is absolutely possible. There are kits that make this possible if you would like to go that route. One such manufacturer is Metra.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 06-21-2007, 05:46 PM   #5
My Photos: (0)
The reason I chose 8" was because in the Rendezvous, the bezel for the radio sits right against the front of the radio, covering about an eighth of an inch all the way around. If I could mount an 8" LCD at the same level as the face of the radio, then the bezel would sit right against it, and look pretty much stock.
I think.
But doing it with a retractable screen and my kenwood saves me having to buy an amp. SO many choices!
Old 06-22-2007, 02:21 PM   #6
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
When I removed my double DIN Bose stereo from my Maxima I installed a single DIN HU and put in an OEM pocket I got at a junkyard. When I built my CarPC I installed a 7" touchscreen, which fits perfectly and almost looks OEM. I had to mod the back of the dash piece to get it to fit, but from the front it looks great. I imagine an 8" would fit in there too.
crooper is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Double din units Vo_Dich Car Audio 2 08-14-2006 09:51 PM
Carputer In Dash Double DIN cases - exist? BFarm Newbie 9 09-10-2005 02:39 PM
Double Din -> Two Single Dins Adapter kirbycope Fabrication 7 06-26-2005 09:39 PM
Help - Opinions on my DIY LCD case (single DIN)? nxt125 General Hardware Discussion 5 10-20-2004 09:34 PM
Double Din Kit for LCD Mount? Plinkey LCD/Display 3 07-13-2004 10:41 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
