Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-22-2007, 01:21 PM   #1
atikali2000 is on a distinguished road
Lightbulb Wiring question...
Hi all,
I have started a fibreglass project for a custom sub build for my Mitsubishi Galant estate boot. Build is going ok, slowly, but in preparation for the wiring phase of the project, I was wondering if there was anything wrong in using domestic electrical cables to the system.
I'm a domestic electrician by trade, so have plenty of wiring about and have looked around at a number of wiring kits. I'm looking to run a 600W max amp with a suitable low powered sub, and not looking to upgrade from this at all (I had the same system in a HUGE ported box in my previous Toyota Corolla, but as I need the boot-space for work, I'm going for a small custom build.
The amplifier has a 20A fuse and the wiring for this is just huge! In domestic cables, 20A can easily be carried by a 1.5mm or 2.5mm CSA cable, but in car wiring kits they are usually 5-6mm CSA wide! Speaker cables also have too much CSA. A 1mm CSA cable could easily take up to 12-15A.
So I was wondering, if I could simply use some domestic wiring in my car (all suitable insulated and protected throughout obviously)? It'll mean I dont have to force a load of super thick wires under my door sill, I can have all my wires take up the same space as an average power lead from a wiring kit!
Cheers,
atikali2000
atikali2000 is offline   Reply With Quote
Advertisement Sponsored links
Old 04-07-2008, 08:11 PM   #2
halfzack is an unknown quantity at this point
how long have you been an electrician? i to have wiring needs. as for using big wire it may be conductivity, like my welder, you need bigger cable the longer you go to take the power, so it dose not melt your wire using high current.
halfzack is offline   Reply With Quote
Old 04-17-2008, 06:13 PM   #3
HisSketchiness is an unknown quantity at this point
The thing to remember is the voltage difference. Domestic houses use 120 V, while a car uses 12 V. That means for the same power, a car will draw 10x as many amps, therefore bigger wire is necessary. Once that is accounted for, domestic wiring should be fine, though it may be stiffer and harder to work with.
HisSketchiness is offline   Reply With Quote
Old 04-17-2008, 07:11 PM   #4
benedums's Avatar
benedums is an unknown quantity at this point
Yikes
The Sketch is correct!
20A on 120AC is way different than 20A on 12DC.
A 100 watt light bulb will draw about 0.8 amps on 120AC.
Where as a 100 watt amp will draw about 8 amps on 12DC.
Amps = Watts/Voltage
Copper is copper, so 12AWG domestic wire will have "roughly" the same current caring capability as 12AWG speaker wire...
And as HisSketchiness said the domestic wire will be a lot more rigid than and stranded speaker wire.
Sailin
________________________________________
CarPC Status:
Planning.......[--------x-] 90%
Parts..........[------x---] 70%
Fabrication....[----x-----] 50%
benedums is offline   Reply With Quote
Old 04-17-2008, 11:21 PM   #5
golfguy's Avatar
golfguy is an unknown quantity at this point
Check out this reference site, it was very helpful to me and I'm sure it will be to you, as well. Remember to always fuse your power runs as close to their source (battery or distribution block) as possible. It's really easy to short something out if you forget to disconnect the battery. You can make some really big sparks and do some real damage if you don't have a fuse on your power line. The fuse in the amp won't protect your battery or car. You should use at least a 12 or maybe 10 AWG wire (sorry, I don't know the Euro equivalent) for your amp.
Any day is a good day for golf.
Mazdaspeed6 Carputer Progress: Gone
(Check Speedy's Install)
Speedy was traded for a 2004 350z - installation will commence Any Day Now
golfguy is offline   Reply With Quote
04 Grand Prix Wiring question djviper108 Car Audio 2 06-19-2007 04:44 PM
Blaxtream TC1000 PSU wiring loom Question??? Aussie Newbie 2 05-12-2007 09:24 AM
simple wiring question yonu Power Supplies 6 01-19-2007 05:00 PM
Wiring question barometer Newbie 2 07-14-2004 06:35 PM
