Snortonnorton
Quote:
I have trouble running it on my 160 wall m2 atx.
look at m2 atx characteristics - it's only 8A on 5v rail
Thats why it couldn't powers your system.
Bazza_84
Cpu stabilizer on your mobo powers from 5 v rail - there is socket A on mobo - so 99,9% 5v rail.Why? - just calculate a current= CPU power/ voltage ( for 5 v and for 12 v rails ) And think about how 1 wire for 12v on 20 pin molex connector can provide high current .... -
it can not(18 or 20 awg)!!! So it powers from 5 v rail. Here is also a way how to choose power supply - calculate current as i described and look at psus characterisics - current on "cpu power" rail must exceed calculated value at minimum 10% , best way 20-30%
here is a different cpu power taking description
http://www.techpowerup.com/cpudb/
Snortonnorton you also can do the same calculations.
If you don't trust me you can just measure input voltage on cpu's core voltage stabilizer by using multimeter, then you will know it 100% which rail
Hah - amd 64 powers really from 12v rail - look at mobos which support them - there is a 12v 4 pin socket like in p4 systems.
