The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 09-06-2007, 10:15 PM   #1
My Photos: (0)
2 vid
i am buying http://store.mp3car.com/Mp3Car_Custo..._p/ccc-121.htm
but i want to know if i can have 2 screen with different thing going on with the TV output cuz they give the output so ....
like if the dirver want the navigation and the people want movie in the tv in the back.
I hope i made my self clear
desidjay is offline   Reply With Quote
Sponsored Links
Old 09-07-2007, 01:24 AM   #2
BiGGy's Avatar
Vehicle: 02 Mitsubishi Magna VR-X
My Photos: (110)
You will be able to get a 'copycat' screen off the onboard video card. If you want the multitasking screen like you explained you will need to buy a PCI video card that supports dual output. If you want both of these screens to be touchscreen its more complicated again same too for smooth front end integration on each screen. This is much more complicated then just plugging in two monitors.
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
BiGGy is offline   Reply With Quote
Old 09-07-2007, 06:11 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-07-2007, 07:37 PM   #4
My Photos: (0)
so wat is the best way..... i dont want both to be touchscreen just one ...
should i just change the PCI Video card to dual one and which PCI video card can i use because i dont know which one will fit of which one is good
help plzz ....
Old 09-07-2007, 09:48 PM   #5
BiGGy's Avatar
My Photos: (110)
The board doesn't come with a PCI video card, its just onboard. You can overwrite it by adding a video card into the free PCI slot that it gives. Though after I did a quick search I could only find PCI 2.2 cards with single video channel. PCI express is needed for the dual video.
What I would do in your situation is run a second computer off your psu and run a touchscreen (or touchpad,trackball etc) for control. This will be much easier for you then trying to juggle the software between screens. The type of computer im talking about is those very low power, cheap solid state ones... like these.
Old 09-08-2007, 07:33 AM   #6
My Photos: (26)
Also, please understand that when you add a PCI video card, your AMpie/Voom case becomes useless, as it is too small to allow for any expansion cards.
There are also USB video adapters, but I'd think they would drag the PC performance down too far to be usable, particularly with the lower-power system you're purchasing. I could be wrong, though.
If they're cheap enough, you might consider buying one just to try it and see if you can achieve the results you want.
My Worklog
Old 09-08-2007, 02:27 PM   #7
My Photos: (0)
i just found another web with wat i i amlooking for like Dual video ouput
http://www.orbitmicro.com/global/bui...oducts_id=4436
but its $160 more an does not have the DVD rom too and i dont know if it has a Shutdown Controllers n if i need it or not helpp ..
thanxx
Old 09-08-2007, 08:35 PM   #8
BiGGy's Avatar
My Photos: (110)
It does come with the m2-atx which has shutdown/startup controlling. It also give you an option for a dvd/rw addition for +$90. So make that $250 mroe then the mp3car one. This seams the cheapest and easiest option for dual video.
Old 09-08-2007, 09:10 PM   #9
My Photos: (0)
i think thats wat i am going to do then ,
i hav one more Q if i have the PC, A 1200W 2 channel Amp with 2 12inc subs, and 3 neon with StreetGlow Music Interface to control them ...do u think it will be no problem or i will have to change the alternator i have a stock alternator with 130 amps for my honda pilot ..
Old 09-13-2007, 12:29 AM   #10
Pint's CarPC Specs
Pint's Avatar
Vehicle: 2004/toyota/kluger
My Photos: (8)
Have you considered getting a roof mounted DVD player instead of another computer. You'll be able to watch movies in the back and have your computer screen in the front. Drawback is you won;t be able to watch movies off your hard drive.....
Also...
The xenarc 700 TSV touchscreen talks about multimonitor touchscreen support. quote: "You can connect several 700TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support"
I'm not sure if this means you can run them independantly. might be worth a look......?
Things to do
  • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
Pint is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
help i want to put a bout 3 8'' screen multi vid split p&gcustoms General Hardware Discussion 9 08-23-2006 05:07 AM
H/W Review- PCI Vid Card 6200- umm $28 VehicrossPC The Review Palace 6 07-31-2006 04:23 PM
laptop wont keep vid settings / Non dock compatable to use with doc hombredelassrta Newbie 0 12-22-2005 09:46 AM
Recommended vid card for 800x480 in linux caenus General Hardware Discussion 5 09-05-2004 11:14 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
