The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 09-15-2007, 12:41 PM   #1
Vehicle: VW Caravelle 2005
My Photos: (0)
Post VW Caravelle/Transporter (T5) wiring
I need to find out if anyone knows of any technical information or wiring diagrams for the VW Caravelle/Transporter (T5 version 2005). These are not sold in the US (Europe and RoW only) so most US wiring sites are useless.
I need to find a suitable wire for the ACC line on my Infill G4 - this is the line that detects that the ignition is on and enables the G4 to power up. The radio wiring harness does not have a suitable wire and the other wires in the dash are generally well covered up and not easy to test without scraping off bits of insulation - which I don't want to do!
Any other T5 transporter/caravelle owners out there?
* Quango in UK *
quango is offline   Reply With Quote
Sponsored Links
Old 09-15-2007, 09:24 PM   #2
Vehicle: 2001/Volkswagen/GTI
My Photos: (10)
Have you tried VWVortex?
Jay_1.8t is offline   Reply With Quote
Old 09-16-2007, 04:08 AM   #3
My Photos: (0)
Had not heard of that one, will give it a try - thanks
* Quango in UK *
Old 09-30-2007, 01:25 PM   #4
My Photos: (0)
Hi there Quango - I am in the same situation and do not have an ACC feed in the Iso Connector - did you find a switched live anywhere?
Cheers
10A :-)
10Amps is offline   Reply With Quote
Old 04-17-2008, 08:56 AM   #5
My Photos: (0)
Lightbulb
Hi, The caravelle / transporter uses can bus so finding on it is a real pain. I have just found a acc line for my rosen dvd system i have just fitted to my 08 caravelle. You can pick up a acc ( switched live on ignition ) from the rear of the lighting switch. You can get to it by gently prising off the side panel from the edge nearest the front drivers seat. You can then use the live and ground by the radio if you require as normal.
If you are fitting a handsfree kit don't bother with a "mute kit" by far the best way is to chop the speaker lead and wire it onto the "phone" plus on the back of the radio. I didn't have a plug so I had to carefully solder onto the pin ( i think they are 6 and 12, they are the only two pins on this plug) Then take the mute wire to the radio mute pin on the back of the radio. This works very well.
I hope this helps!
lowbug is offline   Reply With Quote
Old 06-04-2008, 12:55 PM   #6
My Photos: (0)
The wire you want is a small brown wire with a green trace which can be found if you take the glove box out. The fat loom to the right contains this wire. The loom disappears down to the fuse box area but if you open the loom up where it is cable tied to a metal bracket you can make your connection.
This wire supplies 12v +ve on 1st position of key until key is removed, a true ACC position and not ignition stage 2 (15).
I found this on a 2008 T5 Transporter T30 102PS
Just out of interest, does anyone know where this wire terminates?
sparxy is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Wiring Diagram Audio and Component on a Jetta VW 2000 volfiregon Car Audio 9 08-02-2007 04:02 PM
06 vw passat wiring harness dirtylarry Car Audio 19 06-09-2006 10:36 AM
Help identity this wiring harness VW Monsoon Zip-Lock General MP3Car Discussion 19 10-03-2005 12:44 AM
Interfacing Pioneer AVIC-N2 with VW Jetta Monsoon wiring CharlesPM General Hardware Discussion 2 09-05-2005 10:56 AM
Stock 99 VW Deck -- Wiring MPVW General Hardware Discussion 3 05-15-2004 01:20 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
