The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 09-22-2007, 04:04 PM   #1
My Photos: (0)
Removable amp system and speakers.
Hi all,
Iwas wondering if it was possible to have highgrade connectors to join amp wires and speaker wires so I can take the whole rig out of the back of the car. We have a huge crime rate where I am from. I dont want to wire up my amps and findit going walkies.
Can anyone help.
Millwall123 is offline   Reply With Quote
Sponsored Links
Old 09-22-2007, 04:20 PM   #2
rijndael's CarPC Specs
rijndael's Avatar
Vehicle: 2005 Honda Civic EX SE
My Photos: (0)
i dont quite understand what your trying to do with the wires. try to give an example of what you're trying to do...
Trouble deciding on car speakers? Clicky Clicky
My Myspace page (view my pics for carputer worklog)
Speakers: DLS Ultimate Iridium 6.3 Link
Subwoofer: TC-9 15"
Amplifier#1 (Front Stage): DLS Ultimate A4
Amplifier#2 (Sub) DLS Ultimate A6
rijndael is offline   Reply With Quote
Old 09-22-2007, 05:20 PM   #3
FC3S's Avatar
My Photos: (0)
what isnt there to understand?
he wants to be able to disconnect the wiring from his car and remove the components..
although i dont have an answer for you, hah
FC3S is offline   Reply With Quote
Old 09-23-2007, 03:06 AM   #4
My Photos: (0)
Clarification
I have mounted the amps on a MDF shelve which also contains my 6x9's. I want to be able to take the whole shelve out otherwise it will go via the market in some losers pocket. I was trying to think of the best connectors for this but cant seem to find anything. I need three for the wires going into the amps and several for the wires coming out. Any ideas?
Old 09-23-2007, 06:17 AM   #5
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Very simple. You make that shelf difficult to remove. That would mean attaching it to the body and/or the frame somehow. If it's "just sitting in place", it's an easy target, simply because a thief can break a window or jimmy a dor, reach in, yank on it and he's off.
If there are elements that need to be unbolted, disconnected maneuvered around, etc, then the thief will have a much harder time getting the equipment out. Difficulty means more time, which is what the thief doesn't have.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-23-2007, 06:39 AM   #6
My Photos: (0)
Tried and tested.
We had a whole rig set up in the back of a vw. The rear seats were removed and the speaker + systems was nailed to the floor. Someone stole the car and walked off with the lot. We got the stuff back after the old bill pulled the muppet over and found all of our equipment in the back. Hence the reason I need to remove it at night or when the mrs wants to go shopping.
Old 09-23-2007, 09:23 AM   #7
My Photos: (26)
The missus needs to go shopping in a lower-crime area, to be honest.
In your situation, someone stole the entire vehicle. There isn't a lot you can do about that. If you're concerned about JUST the audio pieces, stealth & secure is the ticket. Hide the pieces and make them difficult to remove.
That's about the best you can do to protect your equipment. A car alarm might help, but a thief that knows what they are doing can defeat that.
Besides, most people ignore a car alarm that's going off, especially if there doesn't appear to be anything going on with the vehicle. Now, if a car alarm is going off and there's someone leaning into a broken window, it might draw some attention.
Even then, it's iffy.
Stealth means that your pieces are hidden to the casual observer. There's nothing that a casual thief can see that they might want to steal.
Difficult to remove means that if a casual thief does see something they want, getting it will be difficult and time-consuming.
Notice I said casual thief. Most thieves are casual, and choose to steal stuff that is opportunistic. That means the target is plainly visible and can be retrieved with little effort. A TomTom sitting on the dash or a poorly-installed high-end headunit fit these criteria. Break a window or jimmy a door, remove the unit and be gone in seconds.
Now, you strap that same headunit to the chassis and it's harder to remove. The thief might break your dash apart and even damage your equipment, but your goods are still there. Your car insurance should cover any damage as a result of the break-in.
You do have full coverage, don't you?
My Worklog
Old 09-23-2007, 10:44 AM   #8
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
XLR Plugs are great for this...
You wire one for pos, one for neg (use one 3 pin and one 4 pin so you don't reverse them). Be sure to wire all pins together, as you need high current to pass without melting the plugs
If you don't want your equipment to get stolen, taking it out is the most secure.
Good luck,
Joachim
JC-S60 is offline   Reply With Quote
Old 09-23-2007, 12:02 PM   #9
AJ3000's Avatar
Vehicle: 2001 Daewoo Lanos 1.4i SE
My Photos: (0)
better than XLRs are Neutrics. they are locking jacks ti which you can wire 2 speakers per connector. they came as standard on XR3i's and Pug 306's. you should be able to get them from any motor factors for aroung £7 (about $15) a peice. i'm a drummer so need to be able to remove all my gear in minutes to fit the kit in, so it's all on Neutric leads, with a false floor with my amps recessed (that removes my 2 clips and the amps are velcro'd to the floor) and i have 2 fibreglass subs (which i'm currently building!) which will also velcro between the false floor and the side of the car. the whole lot ahould come out in about a minute, dead easy!
hope this helps...
East Coast Audio UK
Daewoo Lanos "Woo of Doom" Show Car
Fabrication 4%
Bodywork 0%
carputer 1%
Finish Line - not even in sight!
TOTAL SPENT SO FAR £250
AJ3000 is offline   Reply With Quote
Old 09-23-2007, 12:28 PM   #10
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Another vote for neutriks. I used a four pole neutrik speakon for the power connector in my first setup back in '99. Never gave me any trouble in all the years of use.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Sponsored Links
Old 09-23-2007, 02:31 PM   #11
My Photos: (0)
Cheers thats sorted it. Thanks guys will post when I am finished rebuilding it.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
What to connect to remote AMP on lead for Bose system? msun Car Audio 6 09-19-2007 07:25 PM
No Head Unit? Simy Newbie 16 07-04-2006 10:10 PM
Acura CL Bose System, change Speakers? gswans5 Newbie 8 04-23-2006 08:41 PM
Couple of questions about the monsoon system Bugbyte Car Audio 5 07-07-2005 07:47 PM
matching amp with speakers. ketchup318 Car Audio 2 01-19-2005 01:01 PM
Sponsored Links
Ad Management by RedTyger
