I believe you can save some $$ and use a USB cam - the only problem with that is the PC has to load before your rear view cam works. Depending on your LCD you should be able to plug in RCA jacks into the LCD... So maybe you would need a combo of both. I just want you to be sure that this is just from my past research and I haven't implemented this yet, but I have done a lot of reading because I want to do the same. You can easily buy a RCA to USB adapter if you already have a camera and want it to be USB and RCA - get a splitter and use the adapter...
Project Page - 1993 Wrangler Jeeputer
Progress Meter { **-------} 15% most of the parts are in or have been ordered... Assembly has begun!!!!
