Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 11-13-2007, 09:09 PM   #16
Pint's Avatar
I had a number of problems -
1. I didn't have the M2 ATX connected properly... check that if is connected properly as per the manual i.e the diagram in post #7
2. I had a lot of problems with the Molex connectors that don't provide very good contact - check these.
3. I had simalar problems with my PSU. I couldn't get it to boot properly. It started for a second an then failed. I got around this by disconneciting the motherboard on/off switch (J8). This enabled to PC to startup. ( I have read that switch the polarity if the lead somtimes helps - although it didn't help me)
If you can power up the AMP your amp is okay.
If your motherboard starts up your motherboard is okay.
I suspect that it's your PSU that's causing you grief, which is what my problem was. Since installing the replacement on my machine I haven't had any problems.
I have to mention that at the same time my mother board starting playing up and I ended up replacing that too. I think this was just co-incidental though.
If I get a chance I will ckeck the voltage from the AMP RMT wire.
good luck
Things to do
  • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
Pint is offline   Reply With Quote
Power your car amp, in your house, with a computer power supply syfenx General Hardware Discussion 13 06-12-2008 03:31 AM
need more power to turn on amp brendan Car Audio 18 04-02-2007 12:16 PM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 10:16 PM
Punch 160.4 Amp wont Power unless REM cable is touching Amp casing. Sero Newbie 2 02-26-2006 10:32 PM
How to measure amp draw? Standby sucking to much power? llajumpvid Newbie 1 06-25-2005 01:20 PM
