Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 10-01-2007, 08:05 AM   #1
Pint's Avatar
Pint is an unknown quantity at this point
Power missing to AMP
Hello.
I'm having a couple of power problems with my recently installed setup.
Here's my set-up -
Voom PC
Alpine PDX 4.1 amp
M2 ATX power supply
Affter I connected it all up yestoday there was no power to the AMP.
The PC booted up, but today it won't.
I've checked the supply to the PC and I get 12v from the live wire and 12v from the ignitiion wire.
I've also checked the AMP. I've got a current to the AMP. And when I check the RMT to the AMP from the PC. A couple of different things have happended. Once the AMP powered up for a split second(the lights flashed). On other attempts when I touch the RMT wire at the AMP with the volt meter, the PC powers up. When I touch the RMT wire again, the PC powers off.????
I can't see an on off switch on the amp - is there supposed to be one?
Thanks for your help....
Things to do
  • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
Pint is offline   Reply With Quote
Old 10-01-2007, 08:48 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
The live wire should get 12v all the time.
The ACC should get 0v when the key is off ans 12v when the key is on.
Have you measured the voltage on these lines with key on and key off?
Also, have you checked all your fuses? most amps don't have an on/off switch, just a remote wire that senses ignition state, much the same as your M2ATX PSU.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-01-2007, 09:26 AM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
There has never been an on/off switch on a car audio amplifier that I have ever seen, so that's normal.
However, I must ask how you have your amplifier wired up. Are you powering it off of the M2 or are you powering it off of the car battery?
From your post it seems like you might have it powered off of the M2. I say this because of how you have worded and lumped things together.
Have you checked to make sure you've not put the turn-on lead on the wrong pin on the M2?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 10-01-2007, 05:28 PM   #4
Pint's Avatar
DarquePervert - I'm prettty sure the 12v has live all the time and acc is via the key on and off. I'll double check.
RedGTiVR6 - I'm running the AMP off the battery, through a 80amp wafer fuse.
I'm pretty sure I have wired the pins properly on the M2, but I will double check. (I had to get a replacement internal power cable when the original broke and that could be a possibility)
I have the AMP earthed to the body. I pretty sure that it's a good connection, but I didn't sand the surface becuase it looked like bare metal. Will a less than 100% connection cuase my problems?
I'll check the wiring tonight and if it does'nt work, take the PC out and try it out of the car.
Things to do
Old 10-01-2007, 06:50 PM   #5
Banned
salvi is an unknown quantity at this point
Are you sure that you didn't connect the Ignition wire to your amps instead of the remote wire? If not, check the inside wiring of the plug on the VoomPC and make sure that all wires line up to their corresponding wires outside of the case. I know that there was a case where the wiring was wrong from the inside and outside.
salvi is offline   Reply With Quote
Old 10-01-2007, 10:17 PM   #6
DodgeCummins's Avatar
DodgeCummins
A speaker wiring problem could be causing the amp to remain off also...but check the obvious.
current projects
DodgeCummins is offline   Reply With Quote
Old 10-02-2007, 08:40 AM   #7
Pint's Avatar
okay...
The AMP
There was a loose speaker wire (although I don't think that was my problem). I bypassed the PC and connected the RMT wire directly to a live feed which turned on the AMP. My AMP is good
The PC
Still no power to the PC
I took the PC out and had a closer look.
1. the iginition wire at the molex femal connector was very loose and wasn't connecting to the male. I fixed that. That's why my problem was intermittent and worked for a day.
2. I screwed up when I replaced the power cable.
I had put the AMP RMT into the external on/off switch connector(J9 and not J6). That's why when I touched the wire at the amp the PC was starting up. Fxed that.
I've verified that I have a 12V live to J1 (battery +), and J3 (ignition). I know I have power as the LED on the mother board lights up when it's connected.
The only other thing I've noticed is that it seems that the PSU is not sending a on signal to the motherboard. When I pull the connector off J8 (to the mother board on off switch) the PC starts up until I put the connector back on.
I have the jumper settings set to B 5sec offdelay/2hour hardoff
Not sure what to do next.
how can I tell whether the PSU is fried and I need another one?
Things to do
Old 10-02-2007, 08:30 PM   #8
NorfwocNe is an unknown quantity at this point
Excellent troubleshooting. I'm impressed. Good luck.
NorfwocNe is offline   Reply With Quote
Old 10-03-2007, 08:20 AM   #9
Pint's Avatar
Okay, I'm over it.
Still getting the mobo to start as soon as i unplug the J8 connector. As soon as I plug it in after a few seconds the mobo switches off.
From what I've read, changing the polarity of the J8 connectors might have helped. It didn't .
Back in 2005 there was a thread about the M2 not fully powering all the line and a timing issue which need a PIC fix...... sounds hard if you know nothing about programming like me.
two questions
1. The M2 is 160 watts, will the OPUS 120watt DCx3.120 be suitable for my Voom PC 2 / Jetway mini ITX motherboard?
2. Is PIC programming hard.... can someone recommed somewhere to start?
help is very much appreciated.
Things to do
Old 10-03-2007, 08:30 AM   #10
Uraijit's Avatar
Uraijit is infamous around these parts
So when you disconnect the power jumper cable, the computer boots up? What happens when you reconnect it? Does it just lose power alltogether, or does it initiate shut-down?
I can't help you with programming, but to answer your PSU question, a 120 watt PSU should be fine for that board, provided you're not running a lot of High-current draw peripherals. Would need more info on your setup to say for sure, but the 120w should be fine.
Greedy
-Adj.
Anybody who makes significantly more money than you do.
The Hoe-Puter Worklog
Progress (Phase one):
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Uraijit is offline   Reply With Quote
Old 10-03-2007, 09:44 AM   #11
Pint's Avatar
Thanks Uraijit,
When I disconnect the cables the computer powers up.
When I connect them it is the same as hitting the off switch. It just loses power altogether and switches off.
This happens consistently.
I'm not intending to use a lot of peripherals. -
An internal DVD drive,
2 powered usb hubs for
A blue tooth dongle
silabs radio
griffen volume controller
As a last resort I'll get another PSU. I'm just waiting to see what the M2 ATX mini-box.com people say.
Things to do
Old 10-03-2007, 10:00 AM   #12
Uraijit's Avatar
Good luck getting it worked out. If they don't get you taken care of, a 120 should be plenty suficent for your needs.
Greedy
-Adj.
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Old 10-04-2007, 10:56 AM   #13
Pint's Avatar
Thanks Urajit,
Last resort has come around quickly. I've ordered an Opus. I'm pretty sure the M2 is not right. It starts the motherboard okay but then after a few seconds it shuts it down. I'm pretty sure it's not supposed to do that. I'll send it back under warrenty when the OPUS arrives. I've add a switch to the 12v live so I can use it as a straight PSU. At least I can get it back in the car, whilst I'm waiting for the OPUS.
I got rid of the Molex connectors and replaced them with just spade connectors because they weren't giving me a good connection. In fact they are *****.
I also took at the DVD drive - There's no room for it with it's big ugly 40 pin ribbon cable. I'll see if I can source a shorter cable. The ribbon cable was damaged becuase it was such a tight squeeze.
Where's the question....? The question is -
How do I move this thread to a work log?
Things to do
Old 10-11-2007, 08:52 AM   #14
Pint's Avatar
My OPUS 120W arrived but unfortunelty it does not fit in the VOOM PC case. It is slightly too wide and too long.
Stupid question, but is there anyway to make it fit...... probably not. Silly question really.
I guess I'll just exchange it.....
Things to do
Old 11-13-2007, 07:26 PM   #15
deano_999 is an unknown quantity at this point
Hi, i have a very similar problem with a similar setup...
i have Voom2PC with M2 ATX power supply. i am installing it into a small bus connected to a auxiliary 12V battery bank (as the bus is 24V). i have other things connected to this aux bats (including a 2 Farad Capacitor, 6x100W AMP & also 600W pure sine wave inverter) that work fine, that is not the problem.
so i initially connected the white cable which would normally go to ignition, to a simple switch. reads 12V on / 0V off.
at first i couldnt even get the PC to power up - it would begin to for a sec, then everything would stop with no power to anything, no LED. then in switching it off, the LED would flash once every ~3 seconds.
i can now get it to power & boot up with no probs only if the RMT AMP is not plugged in AND the on/off switch is connected straight to the red main power in. it will not power up with the switch connected to the white? and interesting thing is the RMT AMP out from the PC reads only 3+Volts (instead of what i thought should be 12V) when PC is operating and 1V when turned off. is that normal?
now heres whats got me even more confused... while testing various wires with a digi multimeter, i managed to get it to work as it properly should (with RMT AMP connected and switch to white) - but only when i had the multimeter connected to the RMT AMP (and GND) and the multimeter set to read 200 Ohm resistance or on the Capacitor setting.... i could just leave that multimeter on and the PC would power up perfectly with the switch and the AMP would turn on remotely like its supposed to.... anyone know what this means?
traveling around with a multimeter plugged into the PC constantly is absurd, so i've wired it back to switch the mains in power and a separate switch to turn on my amp. at least ive got it going albeit wired differently - a downside is that turning the power switch off whilst the PC is on will not initiate proper shutdown, just cut power instantly.
if anyone has any ideas? or Pint have you found a solution .... would be much appreciated.
kind regards,
Mike
deano_999 is offline   Reply With Quote
Power your car amp, in your house, with a computer power supply syfenx General Hardware Discussion 13 06-12-2008 04:31 AM
need more power to turn on amp brendan Car Audio 18 04-02-2007 01:16 PM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
Punch 160.4 Amp wont Power unless REM cable is touching Amp casing. Sero Newbie 2 02-26-2006 11:32 PM
How to measure amp draw? Standby sucking to much power? llajumpvid Newbie 1 06-25-2005 02:20 PM
