Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 10-06-2007, 05:04 PM   #1
First time installing Car PC....questions please help
So im installing my first system, and i have everything installed, wired up according to spec and seeing a few weird things.
1. My battery is reading at 17.6V while the engine is on and system is running. It is an Optima redtop battery. Do they show up as more voltage than normal batteries??
2. After the system has been running for about 10 mins it will randomly shut off. In order to turn it back on i need to dis connect power completely then start the car again.
My system consists of:
Optima red top battery 7586dt
MIA MB
Intel core2 duo
120GB SATA HDD
M2-ATX power supply
700TSV touch screen, connected to IGN wire
2 PG amps about 900watts of power, with cap
if you need more info please let me know.
Thanks so much in advance!!
mygti02 is offline   Reply With Quote
Old 10-06-2007, 05:31 PM   #2
_
No - your battery should not be showing 17v. How old is your car and more specifically, your alternator? The only batteries that you would put in your car that would show that are purpose built batteries SPECIFICALLY for SPL competition vehicles...they are 16v batteries.
As for the system turning off after 10 minutes...we need to know what it's doing. Does it hard shut off, does it go through the shut down procedure? Does the battery voltage correlate in any way with it shutting off (over voltage or under voltage?).
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 10-06-2007, 05:37 PM   #3
Red- its a 2002 VW GTI. When the system is shutting off, it is a hard shut off, but when i get it to turn back on it starts up like it was in standby mode. WTf?? right now i have it running with the car off just running on ACC and it has been running for 15mins so far with out issues, but i also have my amps off. would a bad alternator cause it to over charge?
Old 10-06-2007, 05:56 PM   #4
Also, i have the main power running from the CAP, could that mean something?
Old 10-06-2007, 10:13 PM   #5
figured it out, the CPU heat thresh hold was set very low. Running fine now except it does run a little hot with that tiny heatsink
anyone know where i can get a good heatsink and fan for a socket M?
Old 10-07-2007, 08:03 AM   #6
_
http://store.mp3car.com/Cooler_Maste..._p/com-024.htm
Jan Bennett
Old 10-09-2007, 09:54 AM   #7
ordered yesterday thanks Red
Old 10-15-2007, 11:24 AM   #8
Red- I just received that heat sink you showed me, ya its like a fraction of the size to the one i have now LOL thanks for showing me it though....i need to find something about the same size of what i have now, but with a copper heat sink....thats what is killing me, its alum right now
Nifty way to prevent PC from shutting off when leaving car for short time hari-bhari Power Supplies 10 03-08-2007 12:08 PM
First install of car pc working :) optip General Hardware Discussion 2 09-09-2006 07:13 PM
Car PC System Questions arise360 General Hardware Discussion 5 11-02-2004 06:45 PM
Real Time Car tracking now working! Magpie GPS 25 10-27-2004 04:08 AM
