If you read your manual, you would have noticed that the RED wire controls the shutdown timer.
Because you wired it to the ignition switch, the Opus correctly assumes you want to use the shutdown timer.
If you don't want it to shutdown, you need to connect that wire to the same place you connected the rest of your 12v+ wires.
Or, do like I did, and put a toggle switch in the dash to control it...toggle switch on, it powers on, toggle off, it powers off.
If you can't seem to find your instructions...
http://www.opussolutions.com/index.php?p=product&id=49
