The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 10-18-2007, 12:33 AM   #1
My Photos: (0)
Brand New System and the Problems Begin
Alright I will start off with the problems I have no idea how to fix. I have just purchased and installed a liliput 7" indash touchscreen, and a car pc with the M1-ATX power supply. I boot the computer and I get sound for a little while, as soon as I play a song the sound starts cutting in and out. Anyone know why? Second is a problem but I may know the solution. I get a high pitched buzzing noise through the speakers when the computer is running. I believe it is a problem called "ground looping" or something like that. The computer ground is wired to my sub-amp ground, if I move the ground to the head unit ground, will that fix the problem? And last, I wired the white ignition wire, to the white wire coming off of my iginition, when the jumper settings are set to anything other than the setting that is the "act like a normal power supply setting" it will not boot, how do i tell if i wired it to the correct wire?
danthocker is offline   Reply With Quote
Sponsored Links
Old 10-18-2007, 12:54 AM   #2
Grrrmachine's CarPC Specs
Grrrmachine's Avatar
Vehicle: Audi 80 Coupe 1.8 1982
My Photos: (9)
Specific wiring questions won't be solved if we don't know what car the PC is in, as many manufacturers use different wiring colours for the same thing. As for the ground, I would certainly suggest running your own dedicated ground wire (and as short as possible, too) to somewhere on the car.
Other things like your sound problem might be a driver situation - does it do this when connected to regular PC desktop speakers as well?
Grrrmachine is offline   Reply With Quote
Old 10-18-2007, 01:46 AM   #3
My Photos: (0)
It's a 2001 Hyundai Tiburon. I haven't tried regular computer speakers yet, I will try that tomorrow, when I attempt to move the ground connection. Thanks.
Old 10-18-2007, 12:59 PM   #4
My Photos: (0)
Ok I tried changeing the cable and useing regular speakes, neither worked, so I am going out and getting a new sound card now. I haven't moved the ground yet, but if anyone knows about the iginition wire, please let me know.
Old 10-20-2007, 02:30 PM   #5
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
Use a voltmeter or test light. Don't just match color wires.
Use a test light to make sure that white wire is only on with ignition on.
The red wire goes straight to positive on the battery, and the black to a GOOD ground, or to the same ground as the amp, but not AT or on the amp.
Worry about the buzzing sound later...get the PC going first, then read this.
I got lazy and bought a ground loop isolater at Walmart, the thing removed ALL my noise including alternator whine. It's better to not use an isolater though as it removes sound quality.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
93 accord SE: The Lost Cause fluffy2097 Show off your project 20 10-15-2003 03:47 AM
Brake system problems - any experts? kaysee General MP3Car Discussion 7 05-06-2002 04:45 AM
The best in-car system ever L@@K DJ Metro Classified Archive 21 08-22-2001 03:23 PM
What do you think of my playlist?? SkinnyBoy Software & Software Development 19 07-19-2001 12:51 PM
The best operating system for mp3cars brandondere Software & Software Development 29 02-22-2001 12:40 PM
Sponsored Links
Ad Management by RedTyger
