Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 10-18-2007, 03:18 PM   #1
So many devices, so few USB ports
I am in the process of laying out the wiring for my car PC. There are so many USB devices I would like to incorporate that a 4 port hub and 4 ports on the PC are not enough. I will need a second hub.
These are my questions:
Is there any difference/advantage in plugging into the ports directly on the PC instead of a hub?
Can a second hub be plugged into the first hub without problems?
I will be using the following USB devices:
DVD-RW, GPS, XM satelite adapter, 4 port hub, wireless keyboard, bluetooth phone, OBDII, touchscreen, USB dash board open port.
Getting quality goods and service is like buying oats. If you would like clean, fresh oats you must pay a fair price. If you would like oats that have already been through the horse, those are a little cheaper.
JLemieux is offline   Reply With Quote
Old 10-18-2007, 04:47 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
Why not get a single 8-port hub?
Also, check your motherboard. There may be headers for additional USB ports.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 10-18-2007, 06:45 PM   #3
I have no problem using a larger hub. What I whant to know is, for example, would the DVD drive work just as well connected to a hub with several other devices as it would connected straight to the mother board. I don't know how the bus works. My thought is that the one line coming from the hub is now carrying information from several devices on that one line coming from the hub. Is that increased traffic going to slow down all the devices? Would there be a problem watching a DVD with other devices running on the same hub?
As far as checking for additional usb ports on the motherboard I'll have to check the manual. I bought the beginner car computer from MP3Store. Mini ITX mother board? Maybe you know if that has extra usb ports.
Old 10-18-2007, 08:05 PM   #4
Pint's Avatar
From what I can see the begginner's kit comes with a voom PC - Jetway VIA C7 2.0GHz CN700 Mini-ITX Motherboard???. I have one of these and the motherboard does have headers for additional usb ports.
Have you considered running 2 x 4 port hubs of the back ports and distributing the devices so as not to have 2 high traffic devices on the same hub.
Alternativly the VooM PC has a slot for an internal DVD drive. It gets a bit cramped ( I shortened the ribbon cable to increase airflow), but there is room.
Things to do
  • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
Pint is offline   Reply With Quote
Old 10-18-2007, 08:34 PM   #5
I had planned to run 2 - 4 port hubs as I already have one of them.
The PC will be mounted in an area not accessible while driving, so I had the DVD drive external.
Found some good info here: http://www.tomshardware.com/2003/09/...ogy/index.html
It's not exactly what I was looking for, but gave me some insight.
Old 10-18-2007, 09:54 PM   #6
DodgeCummins's Avatar
I would run a powered hub...and try to find one that uses +5...all the ones I have seen use +6...don't know how well that would do plugged into a computer power supply.
current projects
DodgeCummins is offline   Reply With Quote
USB devices help! Focal Newbie 2 04-25-2007 04:46 PM
Extra (hidden) USB ports on Laptop? Nerd2 Laptops, Tablets, UPMCs, etc. 7 03-12-2007 04:07 AM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 11:49 AM
Adding USB ports to Via mobo's Slightly_Stoopi General Hardware Discussion 5 06-06-2006 04:00 AM
Forcing Windows to recognize USB devices on different ports rsd212 General Hardware Discussion 1 12-31-2005 07:27 AM
