Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 12-08-2007, 03:46 AM   #16
Nomader's Avatar
Quote:
Hey all,
Okay so, based on the discussion I am seeing, it is looking like that I need to get a new PSU. I'm looking at the DS ATX 220W (looks to be popular). I like the idea of a com port for programming/statistics. Based on the specs I have, is this sufficient? I just do not want to locked in again. On the flip note, I may have an Opus 120W for sell :-).
look at my specs and you will get an idea:
cpu spempron 2800+ on microATX
512Mb RAM
1 hard disk 200 GB 3.5 inch
1 external 2.5 inch USB hard disk
1 DVD drive (normal size)
1 usb hub 4 ports
creative audigy sound card
onboard sound card (using both sound cards)
Cinergy card (TV, Radio)
GPS , bu353
wireless usb adapter (Netgear)
infrared remote
4 temperature sensors
4 fans
a small usb laser mouse infront (just in case)
a small keyboard infront (under the seat)
and all powered by the DSATX..
the only time i pushed the limits of the PS was when i tried to remove the wireless usb adapter and put a PCI one, that must have sucked a lot of power.. then it started not booting randomly etc.. as soon as i removed it..everything was back to normal!
Nomader is offline   Reply With Quote
Old 12-08-2007, 11:32 AM   #17
Did you check the capacitors on your motherboard (bulges, leaks etc..)? A bad capacitor problem could potentially cause such symptoms.
nobb is offline   Reply With Quote
Old 12-10-2007, 12:51 PM   #18
Naw, we are good in that department
512Mb RAM
1 usb hub 4 ports
GPS , bu353
infrared remote
4 fans
Thanks, that gives me better perspective on what I should expect...
turk30213 is offline   Reply With Quote
Making a Car Computer; Need Your Help! Fear Effect Newbie 20 08-18-2008 09:51 AM
The legalities of wardriving. PURDooM Wireless Communications 200 01-29-2008 05:26 PM
1999 Plymouth Voyager (computer in console between seats) Question Worklogs 14 12-12-2005 11:14 AM
Computer does not turn on immediately Silvino12 Power Supplies 7 10-26-2005 03:51 PM
what can I get to tell the computer to turn on when I turn the car on... mattress Power Supplies 11 02-07-2005 09:55 PM
