Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 10-19-2007, 11:06 AM   #1
dLockers's Avatar
How do I ground my M2-ATX?
I've got a short 8awg wire going from neg on battery to the chassis, is that it? I'm sure I need to run a wire from the M2 to the chassis also, which plug do I go off?
Also:
M2-ATX, how do I make it so I can manually turn it on and off? I'm leaving tomorrow on a camping vacation and haven't the time to wire in and automatic on and off via an ignition.
dLockers is offline   Reply With Quote
Old 10-19-2007, 05:50 PM   #2
muldrick's Avatar
Check the manual.
3 wires, positive, negative, and remote on.
1 Positive = battery power
2 Negative = negative battery
3 Remote-on = Ignition switch.
I think running the wires correctly instead of rigging it will take just as long.
I don't recommend rushing it. I'd do it after the camping trip, and take your time. (lest you fry something)
IE: Do not run a negative wire from the negative to the chassis on the M2-ATX.
Good luck.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 10-21-2007, 05:56 PM   #3
Why don't you want to run the negative of the M2-ATX to the car chassis? Isn't that the same as routing it back to the battery?
MMZonker is offline   Reply With Quote
Old 10-22-2007, 05:34 AM   #4
muldrick's Avatar
Sure, that works, so long it's a good ground.
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Did I break my M2 ATX? CelicaGTS Power Supplies 8 04-29-2007 04:36 PM
m2 atx with hardoff=never Nerd2 Power Supplies 2 04-10-2007 08:53 AM
Re-Ground HU or Ground Loop Isolator? Incinorator Car Audio 5 04-20-2006 07:52 PM
Finding good ground to prevent Ground Loop lookinco Power Supplies 27 11-04-2004 01:23 PM
