The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 10-24-2007, 12:29 AM   #1
Pint's CarPC Specs
Pint's Avatar
Vehicle: 2004/toyota/kluger
My Photos: (8)
Slow down fan speed
My PC is very noisy ..... I know you heard this 1000 times. - Sorry
how di I cut into my 5volt rail to supply my case fans? any pointers would be appreciated. I'm thinking of using the powersupplyfrom my spare USB headers on the motherboard.?
I'm also going to try a vacum pump to suck the air out (instead of blowing it in) and increase air flow. ( I can run the pump outside of the car)
and sit the case on a laptop G-Pad aluminuim heat exchanger to try and drop it another few degrees.
hopefully after all that it should be silent.
Things to do
  • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
Pint is offline   Reply With Quote
Sponsored Links
Old 10-24-2007, 12:45 AM   #2
pRoFiT's CarPC Specs
pRoFiT's Avatar
Vehicle: 91/chevy/S-10
My Photos: (2)
Just pull 5 volts from a hard drive power connector. RED is 5V YELLOW is 12V and black is ground. Done.
1st. How are your fans connected now.
2nd. Not better but....Less power consumption from your power supply if you run your fans on the cars 12volts. Just my thoughts on that. but then you have 13.8 to the fans.
I would build a simple cheap 5 - 8 volt regulator from the cars 13.8 volts and connect the turn on to your accessory on switch. then run your fans from that. a simple lm7805 or 7808 can handle 1 AMP out and 9-28VDC in.
Maybe someone else has a better way to do it?
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline   Reply With Quote
Old 10-24-2007, 01:01 AM   #3
Pint's CarPC Specs
Pint's Avatar
My Photos: (8)
Thanks pRoFIT.
I will use the spare hard drive power connector option. I'm not to worried about the power consumption - My Fans are already powered from the PSU/motherboard.
I tried a voltage regulator for something else and I remeber it got really hot. I don't really want the additionaly wiring effort.....
One more question. I remember 3 wires that connect my fan. I'm assuming I can leave one of them connected to monitor my fan speed?
Things to do
Old 10-25-2007, 06:55 AM   #4
Grrrmachine's CarPC Specs
Grrrmachine's Avatar
Vehicle: Audi 80 Coupe 1.8 1982
My Photos: (9)
Very often 5V isn't enough to give the fan the required kick to get the motor spinning (try running two 12v fans in series and you'll see what I mean.)
Rather than chopping and splicing and crimping and bodging, why not just do what everyone else has been doing for the past 10 years and buy one of these:
Fanmate Fan Speed Controller
Grrrmachine is offline   Reply With Quote
Old 10-25-2007, 10:48 AM   #5
strohj's CarPC Specs
strohj's Avatar
Vehicle: 2004 VW R32 ... 2006 Jeep Commander
My Photos: (0)
OR.. just get a newer ball bearing fan .. I replaced all mine even on my pc's at home.. its soo much quieter now...
strohj is offline   Reply With Quote
Old 10-25-2007, 11:18 PM   #6
Pint's CarPC Specs
Pint's Avatar
My Photos: (8)
Grrrmachine, I tried the fanmate, but I wasn't happy with it as i had to have more wires comming out of my PC and seperate controll units. If I housed them internally (not that I have the room), the heat generated by the controllers becomes a problem. They are no good for me, but they did prove slowing the fans down quitens them down enough for me.
Strohj - I had a look at alternate fans and decided not do that for two reasons
I've got two pretty good/new fans as it is (just a little too noisy for me).
Sourcing better fans proved to be quite difficult......
I'll stick with trying to run them on lower voltage with a heat exchanger to compensate for the decrease in airflow.
Thanks for your suggestions
Things to do
Old 10-25-2007, 11:34 PM   #7
NiSlo's CarPC Specs
NiSlo's Avatar
Vehicle: 06 Impreza Hatch
My Photos: (16)
Google for Speedfan. It's a software based fan controller
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 11-03-2007, 06:26 AM   #8
Pint's CarPC Specs
Pint's Avatar
My Photos: (8)
okay....
I tried Speedfan but it wouldn't work with my ITX machine.
also tried powering my fans with 5Volts but as GRRMachine hinted, they wouldn't start up.
I had a look at quiter fans - but I could'nt find them in Australia and shipping was going to cost me an arm and a leg so I gave up on that idea.
I've gone back to the Fanmate solution. I took the fanmate out of it's plastic and shortened it's cable then plugged them into my fans and squeezed them into my case.
I also screwed a laptop heat exchanger - which is really just a piece of aluminium - to the bottom of my case to help with heat transfer.
My PC is now running quite. Although a little hot. I'll see how it goes and as a last resort put in a vacum air pump to suck out air and improve cooling. I'll post some pictures when I get a chance tomorrow.
Things to do
Old 11-04-2007, 06:43 PM   #9
Pint's CarPC Specs
Pint's Avatar
My Photos: (8)
here's the heat exchanger and fan controllers
Things to do
Old 11-05-2007, 05:25 PM   #10
Moneyfink's CarPC Specs
Moneyfink's Avatar
Vehicle: 2004 Infiniti G35 Coupe
My Photos: (93)
5V is often not enough to kick start your fans, but 7V is
You make 7V by hookinh op the positive wire on the fan to the 12V rail, and the negative wire to the 5V rail. The potential difference is 7 V. I made a homemade fan controller for a case a while ago with a double pole single throw switch (i think thats the right name) anyway, I could select 12V, 7V or Off.....
So what I made was High/low/off That sounds like somehting that may be useful to you.
It cost me under 5 bucks as some fan controlers can cost $30. And if spce is tight this is more barebones
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline   Reply With Quote
Sponsored Links
Old 11-06-2007, 01:13 AM   #11
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
When doing this common trick, remember that your ground is no longer a real ground, and this may affect the behaviour of the 3rd wire used to sense the fans speed. This third wire is usually connected to the motherboard which is expecting the signal to be relative to a real ground.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 11-06-2007, 04:57 PM   #12
Pint's CarPC Specs
Pint's Avatar
My Photos: (8)
I'm new to electrics..... I have two case fans.... is this what you mean?
Things to do
Old 11-06-2007, 05:11 PM   #13
_Dejan_'s CarPC Specs
_Dejan_'s Avatar
Vehicle: 2004/Fiat/Stilo 1.9 JTD 160HP
My Photos: (0)
no. If you want 7V you must use 5V wire by molex for ground by fan(black) and 12V wire by molex for + for fan(red)
so if you look your picture you must change black and red wire on your fan.
P.S. About yellow wire on your fan I don't know if you can put it to motherboard and if you will see right values...
_Dejan_ is offline   Reply With Quote
Old 11-06-2007, 06:14 PM   #14
Pint's CarPC Specs
Pint's Avatar
My Photos: (8)
okay.... like this....
Things to do
Old 11-07-2007, 12:47 AM   #15
_Dejan_'s Avatar
My Photos: (0)
yes this must be ok
Sponsored Links
vB code is On
Trackbacks are Off
How to Speed up Road Runner JohnWPB RR FAQ 4 09-15-2007 01:58 PM
FD Problems... runtime error, speed miscalculation and maps! pdowland FD Bugs 6 11-15-2005 07:13 PM
Feature request: speed camera notifications based on current speed surfatwork Map Monkey 2 08-31-2005 06:01 PM
Tip! Get speed cameras into Centrafuse/D3 Micke Centrafuse 16 07-07-2005 05:33 PM
VIA Epia MII 1200 fan speed/CFM? Snootch General Hardware Discussion 0 05-27-2005 03:21 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
