The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 10-30-2007, 07:46 AM   #1
emperorjj1's Avatar
Vehicle: 06 Cobalt SS Supercharged
My Photos: (0)
screen help and cheap carputer q's
iv been looking at a carputer for quite some time but ive never really had the knowledge to even consider putting one together... So im going to try to get some learning done and maybe build some frankenmonster.
So my first question is Can my Alpine TME-M740BT monitor be used for a carputer? My initial goal was to use it for my RAVDVD1 but i may scrap that hu and or idea. And after reading the faq a few times i got a feeling the answer is no but i thought id ask.
My second question is whats the cheapest setup i can go with? I usually try to get the best of the best the first run so i dont have to upgrade often but theres very few things i need and a just few more i want so im going to try a budget carputer for now.... All i really need is a stereo output, video output, the ability to play music videos and mp3s and a usb port to transfer files to the HDD. I know wifi could do this or dvd but i want to keep it simple and acessable. Now interms of what i want Id like a 5.1 output with some way to get all of those channels to a rca connector for input to the 3sixty.2 processors i have but im thinking stereo would be easier to match the carpueter and headunit levels. Id also like bluetooth and eventually playing computer games would be nice.
So what all should i look at. Id like it to be as basic as possible to i can actually do it and hopefully something cheap so i can afford it (and mess it up while learning)
J. J
http://www.cardomain.com/ride/2604492
TYPE RF System INSTALLED:
RAVDVD1, Front: Silk FNX/FNQ 6.5, Highs amp: 801X
Working on:
Midbass: 8 HX2, Center: 4 FNQ, Midbass Amp: 801s, Center Amp: 301m, Sub Amp: T30001bd, Processors: 2 3Sixty.2
emperorjj1 is offline   Reply With Quote
Sponsored Links
Old 10-30-2007, 09:27 AM   #2
emperorjj1's Avatar
My Photos: (0)
oh ya the screen does have a monitor control lead (no idea wtf that is but says "connect to mcl of a touch panel compitable product
J. J
Working on:
Old 10-30-2007, 10:14 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
You can get a display on that screen IF you can output composite video from the PC or convert the VGA signal to composite. image quality will suffer and you won't be able to control the PC w/ the touchscreen.
do you have computer hardware lying around that you can use? If so, that's the cheapest way to go, by far.
Not everyone is that sort of geek, though.
The FAQ: http://www.mp3car.com/vbulletin/advfaq.php
The Wiki: http://www.mp3car.com/wiki
FAQ Emporium: http://www.mp3car.com/vbulletin/faq-emporium/
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 10-30-2007, 10:22 AM   #4
moboman's CarPC Specs
moboman's Avatar
Vehicle: 1997 Chev Astro Cargo
My Photos: (0)
If you are buying a new motherboard/proccy, and you want brand new. Get the Intel D101GLy mobo/celeron proccy combo. It is mini ITX and costs around 70 bucks I think. That also saves you from installing a processor on the motherboard.
If you were going to buy used, check ebay or the FS section on mp3car.
How much space do you have? Do you need a mini-itx case or will a normal case work?
The M2-ATx, I paid 102 to my door from mp3car.
If you have an old computer lying around, you could simply buy an M2 and use your old computer as your carputer and it would be powered on 12v. If you want, you could use an inverter, but.. inverters suck.
My Worklog
I'm using my carputer 100%, but I still need to make it easier to use.
moboman is offline   Reply With Quote
Old 11-03-2007, 01:21 AM   #5
emperorjj1's Avatar
My Photos: (0)
actually i forgot my old computer took a **** but i havent checked to see on what parts work....
i dont really need a mini itx setup but something thats sorta compact is nice.... Im wondering what all i can get rid of to save space? that way i can try usign bigger componants
J. J
Working on:
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Help on LCD screen gunnt LCD/Display 3 06-17-2002 02:18 PM
Sponsored Links
Ad Management by RedTyger
