Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 11-24-2007, 07:48 AM   #1
VB question
private Sub xMainForm_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Dim inputscore As Integer
Dim score As Integer = 1
Dim scoreCount As Integer
Dim average As String
Dim prompt As Double
Dim title As Integer
Do While inputscore <> String.Empty
If score >= 0 Then
score = inputscore + score
scoreCount = scoreCount + 1
Else
MessageBox.Show(Text, "Total Score", MessageBoxButtons.OK, _
MessageBoxIcon.Information)
End If
inputscore = InputBox(prompt, title, "")
average = score / scoreCount
Loop
I need a little help with this code, want to be able to enter a score from 0 to 10 and then add the total and average out the score. I have total number input box, avg score input and a total score input box. Can someone direct me into the right direction.
Jadi15 is offline   Reply With Quote
Old 11-28-2007, 05:13 PM   #2
galvitron's Avatar
Your description is not really clear but I will try
Dim done as Boolean = false
Dim totalScore as integer = 0
Dim NumberOfScores as integer = 0
Dim inputStr as string = ""
While Not done
'Get a score
inputStr = InputBox()
'If they enter a blank string, exit loop
If inputStr = "" Then
Exit While
End If
'Check for valid integer
Dim i as integer = -1
Try
i = Convert.ToInt32(inputStr)
Catch
Continue While
End Try
'Check for between 1 and 10
If i < 0 Or i > 10 Then
Continue While
End If
totalScore += i
numberOfScores += 1
'Show current average
MsgBox("Average is now: " & (totalScore/numberOfScores).ToSting)
'Go to next input
End While
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 80%
galvitron is offline   Reply With Quote
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 05:15 PM
Complete Newbie Question. DomesticImport Newbie 15 07-07-2005 06:24 PM
VB question. Arathranar Road Runner 5 06-21-2005 12:11 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 09:03 AM
VB Frontend rjstephens Software & Software Development 7 10-05-2002 01:22 AM
