The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 12-05-2007, 09:09 PM   #1
My Photos: (0)
I appreciate your help
Ill start this off as more of a planning guide, then I hope people will make comments. These are just decisions until my knowledge convinces me of a better option along the way or until someone tells me of something better/more convenient/cheaper.
I have a 2006 Cobalt SS/SC.
Here is some relevant info and pics from the forums:
http://www.mp3car.com/vbulletin/newb...ghlight=cobalt
http://www.mp3car.com/vbulletin/newb...cobalt-ss.html
I contemplated where to put this, I will make a new topic in Worklogs with pics I suppose once I get a better grasp on things.
This will probably be under the passenger seat. I will be adding a few extras which I did not include in my list below such as Bluetooth/WiFi/DVDRW in Glove Box.
My needs/wants are listed in priority:
Music/MP3 - Sound quality is a must
Navigation/GPS
DVD/Video
WiFi/Internet
MAYBE:
Bluetooth/Cell Phone integration
HDRadio
PC:
MOBO: (Yes, MicroATX)
Foxconn 45CMX Socket T (LGA775) Intel 945GC Micro ATX
http://www.newegg.com/Product/Produc...82E16813186132
$51
CASE:
APEX DM-318 Black Steel MicroATX Slim Case Computer Case
http://www.newegg.com/Product/Produc...82E16811154062
$66
CPU:
Intel E2140
http://microcenter.com/single_produc...uct_id=0266759
$60
GPS:
GlobalSat BU-353 USB GPS Receiver
http://www.semsons.com/glbuusbgpsre.html
$46
Im pretty sure I will be using iGuidance with this.
POWER SUPPLY:
M2-ATX-HV 160W Intelligent DC-DC PSU
$80
According to this tool, this power supply should be ample provided I power enough stuff off of USB rather than PCI.
http://www.extreme.outervision.com/p...ulatorlite.jsp
HARD DRIVE:
Going to go with a 3.5" 320GB HDD, even if it goes bad, a new one will still be cheaper than a 2.5"
Ill install some rubber padding to offer some shock resistance.
$80
MEMORY:
Crucial 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300)
http://www.newegg.com/Product/Produc...82E16820146571
$27
USB SOUND CARD:
Zalman ZM-RSSC External USB 5.1 Sound Card
$60
TOTAL: $443 + Amp + Wire etc.
AMP:
Pioneer GM-4300F 4-Channel 400W Power Amplifier
or
Pioneer GM-6300F
Would I be OK with the 4300F? My research has led me to believe this, but would the 6300F sound better?
I have a stock Pioneer system:
http://www.pioneerelectronics.com/chevy/index.html
TOUCHSCREEN:
I purchased a 8" Touch screen already and a double din unit (Hope I can make it fit~!)
Thank you all and I appreciate your input and feedback. Negative and positive is encouraged, I want to hear anything really!
MaliceNine is offline   Reply With Quote
Sponsored Links
Old 12-06-2007, 11:47 PM   #2
My Photos: (0)
Looking for reassurance before I pull the trigger on this stuff. Would someone care to tell me if I am going in the wrong direction? Are there better solutions for what I have picked, i.e. better bang for the buck?
I would be very grateful for a response, so I dont waste money on something I dont need or could have gotten better.
60 views and no replies
Old 12-07-2007, 12:08 AM   #3
moboman's CarPC Specs
moboman's Avatar
Vehicle: 1997 Chev Astro Cargo
My Photos: (0)
I don't know if you have checked into it but the mobo/proccy combo I'm using costs like 70 bucks total and it is plenty of power for a carpc.
My Worklog
I'm using my carputer 100%, but I still need to make it easier to use.
moboman is offline   Reply With Quote
Old 12-07-2007, 08:29 AM   #4
My Photos: (0)
what are you planing on running with those amps? if your just running the factory speakers then your gonna blow them in about 10 min.
Mylt1 is offline   Reply With Quote
Old 12-07-2007, 08:36 AM   #5
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
The only reason you would blow your stock speakers is if you don't properly tune the amplifiers using the gains.
I'd also like to point out that those power ratings are max, not RMS...more like 150watts RMS most likely.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 12-07-2007, 07:30 PM   #6
My Photos: (0)
moboman: I figure I will get something up to date, that way it will be semi-future proof, and if I want to pull it out of my car Ill have a decent desktop if I throw in a AC-DC power supply.
I suppose I could use the stock amplifier then. I am glad I could do that, it will save a bunch of money. I will have to find the wire diagram for the amp, and I have searched through the forums and found this problem, which seems to be solved. The problem is a low volume from the carputer. In case anyone else runs into it, here is the thread. And for those more knowledgeable, is this a reliable fix or is it just a cobbled bandaid solution?
I looked, but cant find pictures of the amp, but here are the specs of the stock 06 cobalt amp:
6-Channel High Power Amplifier
* 270 watt peak output power
* 2-Channels front tweeters
* 2-Channels front door speakers
* 2-Channels for 6 x 9" speakers with bridged mono channel for the 10" subwoofer
* 2-ohm stable
* Class-AB operation
* Low distortion output
Old 12-11-2007, 12:55 AM   #7
My Photos: (0)
Update
I ordered everything from the list, except for a few changes.
I got a DSATX instead of the M2ATX, as it was going to be really close on the 12v rail, and probably pretty close or over on the 5v rail(so many USB devices..).
I purchased a different motherboard, http://www.newegg.com/Product/Produc...82E16813135032
$43 AR is a great price for this mobo with all the features it has.
As for the case, I have decided that I wont be able to find a MicroATX to fit under my seat. I am going to buy some plexiglass, make a case, and fit it under my drivers side seat. I want to avoid the trunk if at all possible due to the cold weather and condensation that might occur.
I believe I am going to have to purchase one of the amps listed above and then turn it down to work with my stock speakers/sub. The stock amp does not have RCA inputs. I am wondering if there is a way to still use the stock amp? Some sort of wiring harness with RCA inputs?
Originally I thought my 8" touchscreen was wide screen, which meant it was possible to squeeze into a double din. Turns out it is not, so Ill have to come up with a fiberglass solution or something. Being that I have never fiberglassed before, it should be quite the adventure.
Thanks for your future input guys/girls.
Old 12-11-2007, 03:21 PM   #8
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
When should one worry about condensation?
Is it when the the hardware is much cooler than the air around it?
Has there been reported issues with it? I did a search, and only found potential concerns, but no reports of it happening to someone.
Phatsacks is offline   Reply With Quote
Old 12-11-2007, 04:56 PM   #9
Phatsacks's Avatar
My Photos: (0)
Once again...
Darque to the rescue!
From his irc comments:
Quote:
humidity has no effect on ambient temperature.
The "heat index" or whatever they acall it this year has no bearing on the operation of any electronic device.
Old 12-11-2007, 05:05 PM   #10
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Whoa!
Check fire!
OK....
Admittedly, I walked into a conversation in IRC and did not read the whole thing.
My response was talking about 95 degree temps and high humidity. There was discussion of overclocking and something else.
I assumed (bad idea, I know) that the discussion was about heat dissipation.
Condensation is another matter, however.
Condensation will occur when the water in warmer air comes in contact with a cooler surface. This most often occurs in the early morning hours when the sun starts to warm the air, but your vehicle's sheetmetal is colder. You see condensation (a.k.a. "dew") on your ride and run for the chamois.
I don't think that the interior of the trunk is a likely candidate for condensation, because the temnp differences between the sheetmetal surfaces and the ambient air inside the trunk would bee all that different.
I could be wrong, though. Understand that I've driven a pickup pretty much exclusively for over a decade now, so my trunk knowledge is pretty limited.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Sponsored Links
Old 12-11-2007, 05:10 PM   #11
_
My Photos: (90)
condensation isn't going to be an issue in a trunk...just think about how many folks out there do complete audio installs via their trunks only?!
No need to make it more difficult than it already is, or to recreate the wheel....
Jan Bennett
Old 12-11-2007, 07:04 PM   #12
Phatsacks's Avatar
My Photos: (0)
Well, still sounds good.
I searched the forum, and found lots of potential issues for condensation, and lots of potential solutions.
I didn't see a single instance where someone had condensation mess their stuff up.
Sponsored Links
Trackbacks are Off
Sponsored Links
Ad Management by RedTyger
