The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 12-11-2007, 10:43 PM   #1
Vehicle: 1998 Chevy Blazer, 4dr, 2wd
My Photos: (0)
NewB.. making a list, checking it twice..
trying to find out, if i'm doing this right.
all words in red are questions. if you can help me out, thanks a lot!!
anyways, i'm new to the whole car-pc thing. i found this site and read as much as i could.
this is what i am going to get for my first basic set-up.. and add on/upgrade later on
- Lilliput 7" EBY701 TouchScreen VGA LCD Monitor
BASICS PLUS BEGINNER! Car Computer Package DEAL!
^ does it come w/ a cd-rom drive? or do i have to purchase seperately?
Windows XP or Vista.
Front End:.. haven't checked into them yet, but a free one if anything.
PS3 ThumbPad/Keyboard
4-Port USB Hub
8ga amp kit what size fuse??
w/ distribution blocks and all that good stuff.
My Stereo System as of NOW!
JVC KD-AR7000 HU, has aux-in/cd changer thing in the back. and 4 sets of 5v pre-amp.
Clarion 6.5" Speakers in the 4 doors
Power Acoustik A2400DB amp, 1800w rms @ 1ohm
(2) Alpine Type-R Subwoofers 500w rms/1500w max.. feeding each 900w rms DAILY
Custom subwoofer box, 5cu ft ported, tuned to 32hz
1/0ga knukonceptz amp kit
optima yellow top battery
200a alternator
I want to keep my JVC HU in and hook the carputer up to it. i have seen the faq about how to do it, but i'm still confused. could some one tell me exactly what i have to do for it to work. i have the cd changer thing in the back of my HU. i know i need the aux input line in adapter for that which i then put rca's too that go to ???? i don't want bad sound quality w/ it, but i'm willing to take a little bit of a lose, seeing as my HU plays everything but DVD's any how.. but still, computer w/ no sound = LAME
If there is anything you guys would suggest me to get/use/w.e. then let me know, THANKS.
btw, i have a 1998 Chevy Blazer, 4dr, 2wd.. two tone paint, lowered 3/4, etc etc........
Blazen98 is offline   Reply With Quote
Sponsored Links
Old 12-12-2007, 05:19 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
It doesn't list a CDROM in the package details, so I'd say no.
20A would probably work. If you keep blowing 20A then 30A.
I'm pretty certain a 20A would work...
Now.. Learn WHY a 20A is what you want.
If you don't know why you're using a fuse of that size, you're not going to understand how to troubleshoot if that fuse starts blowing regularly.
What's so confusing bout it?
PC > AUX INPUT on headunit.
If you don't have an AUX input, then you lose the CD changer, get an adapter that allows AUX input through the CD changer and run with it.
I think you need to do some more research, but you're well on your way.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 12-12-2007, 02:56 PM   #3
My Photos: (0)
yes i do need to learn a lot more!! there is just much on here. lol. and i don't like reading ALOT. i guess when i get bored i'll be on the site again reading some more.
as far as the pc to aux input. where do i plug the 3.5mm into at on the pc? do i need to buy a diff sound card. i know if i get a good one it will sound better, but will i be fine at first. until i learn more and UPGRADE.
Old 12-12-2007, 09:51 PM   #4
Bildonia's CarPC Specs
Bildonia's Avatar
Vehicle: 97 BMW 328i
My Photos: (0)
Plug the 3.5mm jack in the sound output port. Usually marked by a green ring around the port. A pci soundcard would sound better than onboard video. Creative is a popular company for cards. Their Audigy card would probably be sufficient.
Bildonia is online now   Reply With Quote
Old 12-12-2007, 10:45 PM   #5
My Photos: (0)
sweet, thanks haha. sound is the only thing holding me back from ordering it all right now. i want to be able to have it thru my hu and i want it to sound as if i'm just playing a cd on my hu. i'm probably going to hold off a couple months and learn more about carputer's before i go ahead and do it tho. besides, it's winter.. no time to be out fussing w/ that kind of stuff. bad enough i'm getting 5 things for x-mas, that i know off, that are all for my blazer and i wont put them on cause it's too cold lol. if i ordered up the pc it would be the same. and prolly a ***** for me to do, as a beginner.. like when i installed my 2way alarm system.. haha
i will keep in touch tho.
thanks for the help,
Old 12-12-2007, 11:39 PM   #6
My Photos: (0)
if you buy an amp kit it will come with a fuse. you dont fuse the object you fuse the size of the wire. 8awg wire i believe uses a 40 amp fuse. what the wire is running should have its own protection. are you running the amp kit to run an inverter to power the pc or are you running it for something else? according to crutchfield that unit already has an aux input. just find out what size it is and all you will need it a male to male 3.5mm plug wire long enough to reach from the pc to the deck.
Mylt1 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Navit - The OpenSource vector based navigation program with routing engine. KaZeR Linux 115 12-01-2007 08:04 AM
first carputer..making hardware list mjs3350 Newbie 40 07-18-2006 01:49 PM
making a list, checking it twice. little help? 702civic Newbie 8 06-12-2004 07:24 PM
MP3 list Tha Hombre MediaCar 3 01-19-2004 06:09 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
