The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 01-05-2008, 04:36 PM   #1
My Photos: (0)
NEWB!! Audio..... help Please
Hello all my MP3car friends.
I have a Jetaway mother board inside of a voompc case. I am trying to hook up and audio cable from the Mother Board to the onboard usb/audio out board. Does any one know which pins i need to connect?
TIA.
Chris
psigti is offline   Reply With Quote
Sponsored Links
Old 01-05-2008, 04:50 PM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
First of all, giving us a brand of motherboard isn't much help.
Second of all, have you considered looking in the manual?
Third & last, why don't you use the audio connectors on the rear of the motherboard?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-05-2008, 05:12 PM   #3
My Photos: (0)
Answer to Question1. Well I figured it wouldnt hurt.
Answer to Question2. Yes and the manual says nothing. http://http://www.via.com.tw/en/prod..._id=202#Manual
If your refuring to the minijack in the back which is intergrated in to the mother board. A Rca audio out to my amp sounds better. and B. There is a broken joint some where in the female part and needs to be replaced. I purchased this Case
because of the fact it had rca outs. Sadly enough neather the case company or VIA gave me a cable. So I need to make my own.
Thanks,
Chris
Old 01-05-2008, 07:11 PM   #4
My Photos: (0)
I used search. I thought sharing the type of MB i had might shed some insight.
yes i looked at both instruction manuals.. they yelded 0 information on pining out a cable or what type of cable to use.
the female audio jacks in the rear are scratchy and the whole reasion i purchased the voom pc case was because it had audio out/rca's
Old 01-06-2008, 07:22 AM   #5
jontz's CarPC Specs
jontz's Avatar
Vehicle: 2001 Ford F-150 Ext. Cab
My Photos: (0)
Hey psigti, I think I found some info for you...
Looking at the connector, the way you took a picture of it, here are the pin outs.
Top row, left to right:
1: Audio out left
2: Audio 5V
3: Audio out right
4: Mic bias
5: Mic
Bottom row, left to right:
1: Audio return left
2: No Connection (No pin!)
3: Audio return right
4: Audio ground
5: Audio ground
You are going to want to use the audio out left and right and the audio ground. The pins on your daughterboard with the RCA jacks should be the same. I hope this helps!
jontz is offline   Reply With Quote
Old 01-06-2008, 12:57 PM   #6
My Photos: (0)
thats perfect thanks. If you dont mind me asking. where did you locate that info?
Old 01-06-2008, 01:06 PM   #7
jontz's CarPC Specs
jontz's Avatar
My Photos: (0)
I actually pulled the info off of my Intel D201GLY2 board. The FP audio connector is identical to yours.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Newb here 02 Audi A4 Avant 02Avant Newbie 0 06-27-2007 05:30 PM
2005 Audi A4 with Symphony Bose audio question atekind Car Audio 20 02-18-2007 07:25 AM
2003 Audi RS6 MRVJ245 Worklogs 0 12-31-2006 02:55 AM
New audio-visual breakthrough for Audi brrman General MP3Car Discussion 3 02-18-2006 08:28 PM
Audi A4 Quattro big pics soz Sunglassesron Show off your project 15 10-23-2003 05:22 PM
Sponsored Links
Ad Management by RedTyger
