Quote: Originally Posted by
Marassa
The only highly proprietary component of G4 is its FM radio tuner - the manufacturer does not officially provide nor support the drivers. AFAIK, only three front-ends support this radio so far: Infill Station (shipped with G4 from the factory), StreetDeck (bundled with G4 from MP3Car.com) and Centrafuse. You can sort of pry the radio software out of StreetDeck or Centrafuse installations but since the software API is proprietary you'll have to resort to programming if you want to use the radio with any other front-end/application.
Yes you can (read the radio warning above) but you'll lose your support from MP3car.com if you do that.
Marassa - thanks very much for your informative reply. Do you, or anybody, know if there are plans to allow Sirius satellite radio on the G4 instead of XM?
Also, if you wanted to buy a prebuilt system, would you choose the G4 or is there another prebuilt car pc I should look at?
Thanks again,
Greg.
