The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 02-01-2008, 07:00 PM   #1
My Photos: (0)
Recommended gauge
I am looking and contacting people who might know about my Tracker trying to figure the best way through the firewall to mount my amp and have power for the future carputer. Now I have to fuse the amp obviously...the Sony amp instructions say no further than 18 inches from the battery and it needs a 50 A fuse...but nothing about the gauge of the wire.
Here are my thoughts...and I need you input. I like to over plan for power. So I was thinking put a 2 gauge wire to the fuse. At Walmart when i was board one day i found their wire kits...they have ones with a fuse holder that split 1 wire to 2 fuses and 2 wires from that of lesser gauge. So I was thinking 2 gauge to fuse...4 gauge to the amp from the 50A fuse and the other ...er..."insert number here later"A to the carputer via 4 gauge also. What do you think?
Another odd this I noticed...the PSU's I have seen, they all seem to have really thin wires for the power and other wires. Is this right? i take it they don't need a huge gauge wire really.
DracoPCGuy is offline   Reply With Quote
Sponsored Links
Old 02-02-2008, 01:06 PM   #2
epod86's CarPC Specs
epod86's Avatar
Vehicle: 2006 Mustang GT - 5 speed
My Photos: (0)
have a look at this FAQ.
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=5
It has a good table that shows you what gauges to use where depending on current draw and length. Generally you up those gauges if the wire is being hooked to something that is sensitive to noise (like an amp). Depending on where you're putting your components, that will determine the gauge you will need.
Car PC Progress:
Planning: 90%
Parts: 90%
Fabrication: 10%
Installation: 0%
OS: 60%
Software: 20%
epod86 is offline   Reply With Quote
Old 02-02-2008, 02:13 PM   #3
My Photos: (0)
www.the12volt.com has power wire charts.
8 guage would be sufficient for that amp, so a single 4 guage for amp + car puter should be fine.
pokki is offline   Reply With Quote
Old 03-31-2008, 10:42 PM   #4
My Photos: (0)
I could have gotten away with 8 gauge for just the amp according to the charts i looked into but I decided incase I upgrade later I pulled 4 gauge. I just think its better rather than ripping out the 8 cause the new amo needs 4...so I am set with my mp3 player for the mean time. Thanks for your help. - http://www.mp3car.com/vbulletin/work...y-tracker.html -
Sponsored Links
vB code is On
Trackbacks are Off
What gauge wire for 800w inverter? Milky Power Supplies 9 10-31-2006 06:36 AM
Any Gauge Face Creation Ideas? xhazn Fabrication 14 05-18-2005 08:09 AM
Best way to connect 8 gauge wire to 12-16 gauge wire? SwapMeet Car Audio 22 03-09-2005 10:27 AM
Mounting motherboard in WRX gauge pod housing.. Giuliano General Hardware Discussion 0 07-19-2004 09:01 AM
question about relays and high gauge wires Heedunk General MP3Car Discussion 12 05-10-2001 11:13 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
