The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 02-05-2008, 03:21 PM   #1
Vehicle: 2001 Nissan Altima
My Photos: (3)
Aopen Vs Mac Mini
I am trying to figure out what computer to use in my install and have narrowed it down to either a mac mini or an aopen pc. I would like to install it in my dashboard. Does anyone have a preference or experience with either?
I like the aopen because it works with carnetix power regulator, has USB ports on the front of the case, has a remote control and I can put the wireless receivers external to the case for better range.
I like the mac mini, because it works with the carnetix power regulator, has a remote control, I will not need to assemble it and I like the possibility of being able to play around with a mac. I have always been a PC owner, and am looking for an excuse to see what all of the fuss is about with macs. Does anyone know if you can use popular front ends and software on Mac OSX, or do you need Windows.
Any advice related to using Mac OSX, mac minis or aopen would be greatly appreciated. Thanks.
-Ross
gunsandrosses is offline   Reply With Quote
Sponsored Links
Old 02-05-2008, 03:43 PM   #2
My Photos: (0)
I'd love to help you decide between either the AOpen MiniPC or the Mac Mini, but I don't know that I can. They both have beneficial factors and the true deciding factor is what your looking for in a CarPC.
Personally, I would recommend building a custom system, but if thats not an option I would purchase the Mac Mini. Macs are beautiful pieces of hardware, and OS X is an amazing operating system with some great features that Windows simply cannot match.
As for your question about front end applications, Roadrunner, probably the most popular front end software is only available on Windows. You can still use it on your Mac, but you will have to use either bootcamp or virtual machine software like VMWare or Parallels. StreetDeck, another popular front end application is also only available on Windows.
However, there are a few front end applications that have been developed for the Mac, such as QCar, CarFrontEnd, Neon Boombox, and AMP. If you do go with the Mac Mini, you can always try those out before running Windows.
Best of luck to you!
BrendanWelsh is offline   Reply With Quote
Old 02-05-2008, 04:01 PM   #3
My Photos: (3)
I suppose I could get the mac mini and if I don't like the mac front ends I could switch to windows. I have been reading about them on the forums and they seem like they require a good bit of customization. Unfortunately I'm not a programmer. I'm also assuming that using virtual machine software has an affect of boot times. I kind of like the idea of being able to customize and upgrade my hardware as necessary. I'll probably stick with Aopen.
-Ross
Old 02-05-2008, 04:13 PM   #4
My Photos: (0)
You read correctly in reading that they require a bit of customization, but you would probably be able to overcome it with a bit of research and learning.
Your also correct in assuming that Virtual Machine software will affect your boot times, it will. Bootcamp probably wouldn't -- but it would be much more inconvenient.
If your looking to upgrade and customize, the AOpen MiniPC is definitely what you want to get. I'm sure you know that Macs allow little-to-no customization, so if your looking to upgrade you are making the right choice in sticking with the AOpen.
I'm sure you will be happy with either one, but from what I understand the AOpen seems more suitable for your needs.
Considering installing a CarPC as my senior project.
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 02:24 AM
Mac mini (Intel) and CNX-P2140 atl MacCar 9 08-19-2007 12:26 PM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
Mini Mac 4 Porsche 944 4thChild MacCar 13 06-20-2006 07:57 AM
Hot Rod Company to start incorporating Mac Minis stacheldraht MacCar 4 02-01-2005 12:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
