My XOVision 750watt inverter died last month, but before that it worked perfectly with no problems, and no scan lines in my Lilliput monitor.
Recently, I bought a 1000watt Lenmar inverter. And after hooking it up, I now have scan lines in my Lilliput. Its like slow bars scrolling up the screen, if you can picture that.
I read the FAQ's and the tip was to change the refresh rate to 75hertz, which I did. But it didnt help very much. And this imo is irrelevant because it was working perfect before I changed inverters.
So, my guess is its a grounding issue. Thats why I posted a picture of the ground I have hooked up to my inverter here so you guys can see it, and I wanted your opinion if it is a good ground spot or not. I scuffed the bottom of the bolt to get a better connection, as you can see in the pictures.
I would think that would be a great ground point, but I guess I could be wrong?
Thanks alot for the help guys, I really do appreciate it...
