Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-02-2008, 12:17 PM   #16
iomandala's Avatar
I live one block away from the allentown farmers market no joke come summer let me know when you are headed up here
I think i watched to much night rider
iomandala is offline   Reply With Quote
Old 03-02-2008, 12:23 PM   #17
brucedog's Avatar
Wow. You really mean the farmers market directly off the NE extension, the rest stop?
Didn't know there were any houses around there....
Happy CarPC'ing!
brucedog is offline   Reply With Quote
Old 03-03-2008, 11:12 AM   #18
iomandala's Avatar
No thats different im not to far off from there though.
Old 03-03-2008, 11:43 AM   #19
greatwhite's Avatar
Quote: Originally Posted by iomandala View Post
Well last night i took apart my old laptop a HP pavilion ze 4500 and found out all the parts and where i am going to start here. I have the dimensions and now i think i have a clear idea of what i would like to accomplish.this is a list of things i still need input on. I have mentioned this in another newbie post but i drive a VW 2004 GTI VR6 24v with a factory double din with the monsoon amp.
How can i get a key switch signal to put the computer into hibernate?
How can i relocate the cd/dvd drive and can i use a super drive with this computer?
What is the best inverter if i wonted to use a 12v lighter for power?
And what is the best overall front end in the xp platform?
I plan to use the monsoon I have read about this but any more diagrams and volt amp signal charts and mapping would really help. I also do not wont to alter the factory wiring I am trying to accomplish a plug and play unit where and if at all possible.
Thank you for any and all comments.
1. Since you're running a laptop and assuming you'll still have the battery installed, simply set the preferences in xp to hibernate after "X" minutes when running on battery power.
2. Get a usb enclosure from newegg, mp3car, or ebay. They're cheap.
3. if you're going to use a laptop, get one of those "airline" adapters for your model. then either plug it into the cig lighter OR cut off the plug and wire it into the vehicle properly. Either way is much better than an inverter.
4. Best front end for xp? Depends on what you want. Road Runner is the most popular though. It's free, there's an unlimited amount of applications and plugins for it, and guino(creator) actively updates and tweaks it. It does require a little knowledge and willingness to experiment on your part. If you want a more "out of the box" solution, look into streetdeck or centrafuse, they're available for purchase and are a bit more sorted right from the get go. But you loose some configurability for that stable known platform, and there aren't as many plugin's for them like RR...........
5. Plug and play. Unnghhh..........I cringe when people say this. Never the best way and it always looks cobbled up.
6. Don't want to alter the factory wiring? Exactly where do you plan to draw power from? Please don't say plug into the cig lighter....................
But;
If you really want to keep the head unit, either use it's rca in jacks, hack some in if it doesn't have any, or plug the puter into the 3.5 jack (again if you're HU has one).
Overall, a decent way to go if you're on a strick budget (ie; you're nearly broke!). But it's always going to be a "half way" solution.
I'm a big fan of not going half way with anything. A laptop, inverter and touch screen run through the HU can be made to work but you'll never be satisfied with it. It'll always look tacked on at best, crappy at worst. It will play MP3's, it will run nav software, but so will a laptop sitting on your passenger seat.
Which is pretty much what you are making.
If you want to go this way, just get one of those laptop gooseneck mounts and be done with it. It'll be much cheaper and you can still use the laptop as a laptop.
Now, what I would recommend (notice I said recommend) is a micro/mini/small form factor atx board, a proper "intelligent" dc-dc power supply, integrating a touch screen into the dash, appropriate peripherals for what you want (gps mouse, HD radio, etc), the coresponding audio hardware, and ditching that stock audio system.
This will require a fair time and financial investment on your part (depending on what you have lying around already), but the end result is much more satisfying.
But the choice is up to you.....................(and your budget!)
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 03-04-2008, 06:04 PM   #20
iomandala's Avatar
I have really been doing a lot of reading on hear i think i know what i wont. I don't have the battery for the laptop if was fried. I am using a apple USB supper drive because the drive on the laptop is fried.I have found the wirening harness and i think i found the power supple i wont to use i will have a list and a diagram of what i know so far up soon.
Old 03-09-2008, 05:01 PM   #21
iomandala's Avatar
This is what i think i got so far.
7" Lilliput touch screen
Carnetix CNX-P2140 power supply
Apple USB supper drive for the mac book air
Blutooth USB
I am planing to put the supper drive and the mother board in a custom made box in the glove box the screen will be a double din fit with a custom bezel and the power supplie will be located where the old head unit was.
I plan to use a vw wiring harness from the dealer and when i am done the only thing on the car exept a few hole to be altered from the factory will be the glove box.
Should have everything going as soon as i get a job and some money.
Old 03-21-2008, 12:57 PM   #22
iomandala's Avatar
I found this on amazon do you think its worth a damb
http://www.amazon.com/GOLDEN-Double-...121935&sr=1-10
I am going to run my mother board under my seat its just easy that way. I just need to find out what power supply i should use. Any comments welcome.
Old 03-21-2008, 01:21 PM   #23
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
No. It uses video as the input and your computer will appear fuzzy. You want a VGA screen.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 03-21-2008, 08:07 PM   #24
iomandala's Avatar
thank you
Old 04-08-2008, 11:35 PM   #25
iomandala's Avatar
I think i got it
I have been really broke but after a little screwing around with my glove box i realized that my pc will not work the best there. Im going to be putting the mother board and the power supplie under the seat. this should make life really easy. I know what i wont to use now i just have to buy it and install it im working 2 full time jobs right now so it should not take me more then a few months i will post again when things are up and running.
Text Imput..Multi-Tap liquid_smoke PhoneControl 10 01-09-2005 12:05 AM
need a little imput heynicecar LCD/Display 3 12-28-2004 08:11 PM
No imput signal greenspider Newbie 3 12-10-2004 06:20 AM
Imput on this set up?????? Matt Erich General Hardware Discussion 2 03-30-2004 08:06 AM
Deck Imput and feed back qball008 General Hardware Discussion 0 03-22-2002 08:58 PM
