The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 03-27-2008, 10:14 AM   #1
Vehicle: Seat Ibiza '02 101hp
My Photos: (0)
Question AWG wiring issue on M2-ATX...???
Greetings!
Tomorrow i'm going to purchase wire in order to connect my M2-ATX plus a DC-DC regulator to car's battery and ignition (owner of seat ibiza '04)...
So as i see M2 package includes wiring of 14AWG (i don't remember right now the insulation temperature limit but certainly isn't low)...
What do u people propose? Should i buy an 14 AWG wiring running through the dash to the engine's battery (this means that wiring will not be in the open air so proper diameter and insulation must be used in order to prevent current temperature increase)?
I have been really confused about this matter so some help will be much appreciated..
PS.
Wiring won't be longer than 13-15 feet (4.5-5 meters) and as i am calculating the maximum amperage may not exceed 15 amps... I'm also concerned about high ambient temperatures in summer period (35-40 Celsius degrees)..
Nazx is offline   Reply With Quote
Sponsored Links
Old 03-27-2008, 05:39 PM   #2
My Photos: (0)
Come on guys...
nobody knows? so many people installed a M2-ATX psu and nobody can provide some info about the diameter of the wiring he used??
in a couple of hours i' m going to buy some wire so don't get bored to give some advise here!...
Old 03-27-2008, 10:08 PM   #3
BlackStealth's CarPC Specs
Vehicle: 93 Twin Turbo Dodge Stealth
My Photos: (12)
When it doubt, buy the larger gauge wire. I'm using 8 gauge wire going to my trunk.
BlackStealth is offline   Reply With Quote
Old 03-28-2008, 07:01 AM   #4
My Photos: (0)
hello! thanx for ur answer! u got a point on that but more thicker wire means also more space must be available through car's chassis holes..! As I read somewhere:
"For short lengths of wire, such as is used in battery packs you should trade off the resistance and load with size, weight, and flexibility."
anybody else? any opinions about u people who used M2-ATX?
Old 03-28-2008, 08:48 PM   #5
NotYou's CarPC Specs
Vehicle: 99 Jeep Wrangler / 07 Grand Cherokee
My Photos: (10)
The m2-atx is rated for 160watts, so I would recommend running 10 or 12gauge wire. I personally will be using 10 gauge wire, just because it was economical for me to purchase.
12 or 14 gauge wire will work fine as well, especially if your not using the m2-atx to its rated limits. You can either attach a new spade connector to the end of your wire, or use a butt splice to connect your wire to the short wires that are included with the package.
The most important thing to do is look for some wire that has a thicker plastic covering then "normal" wire at the same gauge. This helps to protect the wire better in a car environment, and reduces the chance of a short happening because of rubbing or sharp metal.
PS. Why the DC-DC regulator? The m2-atx has very decent regulation on the output voltages it products.
NotYou is offline   Reply With Quote
Old 03-28-2008, 08:56 PM   #6
galvitron's CarPC Specs
galvitron's Avatar
Vehicle: 2006 Evo MR
My Photos: (0)
I run 12 gauge from the battery to the M2 with an extra 15amp fuse by the battery. I used some copper speaker cable that had really thick insulation so that it would not get damaged in the engine bay.
Make sure to run the same size wire to your ground point for the M2 (not less).
The M2 has a 15amp fuse built in so another fuse is not necessary but I like to be extra safe. But don't bother if your fuse is above 15amps.
Are you pushing the M2 to it's limit? If not you can go with 12 gauge or smaller depending on the usage but you may want to put a 10amp fuse or something if your system is using 100 watts or less.
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 60%
galvitron is offline   Reply With Quote
Old 03-28-2008, 09:02 PM   #7
My Photos: (10)
Ah yes, thank you for putting that in there for the OP -- I forgot to.
Even though the m2-atx has a fuse internal, that will only protect the m2-atx in case of a short. You need to have another fuse within 18 inches (preferably within 12 inches) of the battery. This will protect the battery in case of a short, and at the same time protect other devices from getting overloaded during that short.
Old 03-28-2008, 09:03 PM   #8
galvitron's Avatar
My Photos: (0)
^^^ Definitely. Ignore my comment about it not being necessary.
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 60%
Old 03-29-2008, 07:43 AM   #9
My Photos: (0)
Hmmm... 10 gauge wire with extra plastic insulation will be fine as I see.. even using a 12 or 14 gauge will be perfect using a smaller fuse protecting from overload...
of course a second fuse on the battery's fuse block is a "must"...
about dc-dc regulator u mentioned before... No, it will not be used in serial with M2 as (u correctly said that) it has perfect regulation! I will use the regulator for future expansion outside the carpc's case, so I hv to "predict" the wattage will be required for that, while now i'm in the wiring phase..!
Thanx for your answers guys...! Much appreciated!
Old 03-29-2008, 08:58 AM   #10
My Photos: (0)
Guys one more question....
the WHITE wire (ignition signal) to the M2-ATX how much awg cable must be?
I mean is it only used for ignition signal and automation in M2 or is it used to power up, in a matter, the M2?
Sponsored Links
Old 03-29-2008, 09:40 AM   #11
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
The white is just a signal wire. It can be a paperclip draws milliamps. So any car wire even speaker wire is fine for the acc line of the M1/M2/M3/Opus/DSATX
Old 03-29-2008, 09:56 AM   #12
My Photos: (0)
As I thought so!! Thanx about that man!
Old 03-30-2008, 10:06 PM   #13
BlazingBird's Avatar
My Photos: (0)
M2-atx
I used a 12 guage, and spliced it into my power line from the factory wiring harness. Works !!
BlazingBird is offline   Reply With Quote
Old 03-31-2008, 07:00 PM   #14
My Photos: (10)
If you are running your M2-ATX close to its rated capacity, I would be careful with this. Generally the factory wires are 18 or 20 gauge wire. Even though you have attached a larger gauge wire to the factory harness, your effective wire size is the smallest gauge used -- in this cause, the 18 or 20 gauge wire from the factory harness.
If you run the m2-ATX close to its rated capacity, you can cause the smaller factory harness wire to heat up, and possibly melt its insulation under the heat. Then, since factory bundles multiple wires together closely, there's a chance of shorting out between those wires or catching something on fire.
Again.. it probably works fine and hasn't given you any trouble, but it could in the future if you run the m2-atx close to its rated capacity. I would suggest taking your 12 gauge wire all the way to the battery instead
Old 03-31-2008, 07:03 PM   #15
galvitron's Avatar
My Photos: (0)
The car's factory 12V line into that harness is going to be small for an M2...
Much better to run a dedicated fused wire from the battery.
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 60%
Sponsored Links
vB code is On
Trackbacks are Off
Xbox w/ M2 ATX and PSU convertor MiniRX7 Power Supplies 1 11-25-2007 06:45 AM
m2 ATX 160 Watt - voltage irregular? MiniRX7 Power Supplies 2 11-16-2007 10:32 AM
M2 ATX installation trouble with ignition signal? Snortonnorton Power Supplies 16 07-26-2007 12:55 PM
M2 to car stereo wiring concerns,.... MrSkipsey Power Supplies 2 06-11-2007 01:08 PM
Help With Fuses silv3rman Power Supplies 32 05-22-2006 08:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
