The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 03-27-2008, 01:25 PM   #1
Vehicle: 05/nissan/sentra
My Photos: (0)
Starten to make a carputer "need input"
Ok I been thinking and researching for part to make a good carputer.
here is a list that I tend on buying and if the part are good to get please tell me but if there might be a better part than the one Im getting I would like some help please well the most important part is motherboard. I plan on getting a
Mini-ITX motherboard Which cost $60
# VIA CLE266 chipset+VT8235M
# One DDR memory slot
# 1GHZ CPU motherboard on board
# 2 x IDE (Hard drive connectors)
# Rear I/O pannel: PS2 KB+PS2 Mouse connectors+Parallel Port+Com Port+15 Pin VGA port+4 USB connectors+10/100 port+sounds.
# Motherboard size: 17cm x 19cm
and some memory
Carnetix CNX P1900 DC DC Regulator $99..
I already have a hard drive thats 200Gb with external case
so right now its only $159 Im spending, Ill worry about the monitor later till I get a working desktop or I can take the one i just built which is a
(already built)
-MSI-K8N Neo4 motherboard
-AMD Athlon 64x2 3800 dual core processore
-2Ghz 1gb corsair memory
-200gb maxtor hard drive
-and I forgot wat kind of graphic card i put in it but i think its 512mb
so I could just make a slim case and stick it in trunk but i dunno if i want that kind of power supply for a carputer.. and booting might take a like 8-14secs..and i still dont know wat kind of power supply to use for it in the car though.
lilsentra84 is offline   Reply With Quote
Sponsored Links
Old 03-27-2008, 01:33 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Thread moved to Newbie section.
Google "VIA CLE266" and the first link will take you to VIA's tech specs that tell you what kind of memory to use.
The most important part of a Car PC, IMHO, is the power supply and screen. Almost anything can be used as the computer hardware.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 03-27-2008, 02:32 PM   #3
My Photos: (0)
If i go with my already made at home desktop what kind of power supply would i use to put it in the car.? i would really like some help on choosing a good power supply.
this is how it was coming alone till i seen people putting pc in cars heh.. and made me wana put mine in my car. and I drew/painted the skulls on
Old 03-27-2008, 04:55 PM   #4
Bugbyte's Avatar
My Photos: (19)
The answer is in the FAQ's right here.
Old 03-27-2008, 09:54 PM   #5
My Photos: (0)
ok so I did all that and this is what I came up with.
Athlon 64-3800+
(2.4GHz - 512KB) ?V
(?V~?V) ?V ?A 89W 65° C
Motherboard w/on-board devices 1.50 1.00 0.20 12.35 W
System fan 0.15 1.80 W
Processor fan 0.15 3.60 W
Memory (per 128MB of DDR) 0.40 4.00 W
AGP Video card 2.00 6.60 W
PCI Sound 0.50 0.50 4.15 W
5400rpm 3.5" IDE Hard Drive 0.90 1.80 26.10 W
CD-RW Drive 1.20 0.80 15.60 W
DVD Drive 1.20 1.10 19.20 W
USB devices 0.50 5.00 W
Keyboard 0.05 0.25 W
Mouse 0.03 0.15 W
Totals 4.00 A 6.68 A 4.35 A 98.80 W
ok... so my cpu is 89w and my system is 98w so i can just get a regular? power supply like the one i listed without getting the regulator? or i still have to get regulator.. this is confusing me i dunno why but it is... help please..?
Old 03-28-2008, 08:16 AM   #6
Bugbyte's Avatar
My Photos: (19)
Do you mean that your CPU is 98 watts and your System is an additional 89 watts for a total of 187 watts? That sounds about right. You need additional overhead because there are higher draws on startup. A 250 watt power supply would probably work.
If you get a DC-DC power supply, they usually have regulation built in unless they are cheap. You need regulation because the voltage in your car fluctuates and is subject to electrical noise and interference.
Old 03-28-2008, 09:45 AM   #7
My Photos: (0)
ok great man thank so much for all you're input you are such help.
So I went and looked at the power supplies ya'll sell and I only see this one that only 220Ws and one thats 320Ws but I think that will fry it. But if I do get the 220w I wouldn't need the dc-dc regulator right since its programed in the power supply?
Im thinking of also just getting a separate battery to run this high power pc. is this a good idea? that way it don't suck up to much of the juice from the car it self?
Sponsored Links
vB code is On
Trackbacks are Off
99 Acura TL carputer project pics Darkshear Show off your project 15 08-23-2007 12:14 AM
Good time to buy carputer components? Linus General MP3Car Discussion 19 11-25-2004 08:57 PM
How can I make my carputer run longer? Bobby Digital Power Supplies 13 10-24-2004 01:36 PM
Microsoft to make Carputer. LESLIEx317537 General MP3Car Discussion 30 12-04-2003 04:07 AM
This new motherboard should make installing a carputer MUCH simpler. Szech General Hardware Discussion 8 11-08-2001 12:41 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
