The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-08-2008, 09:15 AM   #16
Cocide's Avatar
Vehicle: 96 Miata
My Photos: (0)
one thing I did not take into concieration is if a relay will fire that fast or if the relay itself will become warn out.
Will I have to get a special relay to handle pulsing every 1 - 10 ms?
Planing [=====>] 90%
Coding [===>----] 50%
Interface [=>-------] 25%
Hardware [>---------] 10%
Install [-----------] 0%
Cocide is offline   Reply With Quote
Sponsored Links
Old 04-08-2008, 09:57 AM   #17
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Yes, something with no moving parts would be best, solid state relay for example.
Having a mechanical relay kick back and forth at 100 to 1000 times a second is going to end in tears, not mention the buzzing will get very annoying very quickly I'd guess.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 04-08-2008, 10:52 AM   #18
Cocide's Avatar
Vehicle: 96 Miata
My Photos: (0)
Well digikey it is then.
Thanks again for all the help.
Old 07-02-2008, 09:59 PM   #19
My Photos: (0)
The best way to control a blower i found is by using PWM with a high current solid state device, not a relay!!.Im actually currently working on a 15 amp PWM controller with 15 different speed seetings. This is designed to be an add-on to the fusion brain. The only thing is that you need to sacrifice 5 outputs. I also have another add-on that increases the availiable ouputs. Im sure the fusion brain could also make these, but im very impatient. If anyone needs more info let me know, im willing to help.
Civic Modz is offline   Reply With Quote
Old 07-02-2008, 11:30 PM   #20
stonestatue's Avatar
Vehicle: 93/Chevy/G20
My Photos: (0)
PM sent.
Self proclaimed environmentalist.
stonestatue is offline   Reply With Quote
Sponsored Links
Old 07-02-2008, 11:58 PM   #21
My Photos: (0)
Oh sorry I seen what you are trying to acheive now. Yes if you connect relays it will simulate you changing different fan speeds, all your doing is basically switching the power to different resistors. This is exactly what I did though I wasnt happy with only 4 speeds. By using PWM I changed it to 15 different speed settings.
Sponsored Links
vB code is On
Trackbacks are Off
Control devices via LPT and Bluetooth Towar Software & Software Development 9 12-16-2007 10:46 AM
Need wiring help for 2005 Grand Prix. derekmac Car Audio 33 09-21-2007 09:42 PM
Climate Control optimization 300Pilot Software & Software Development 3 09-23-2006 09:28 AM
mercury sable w/ electronic climate control sgibbers17 General Hardware Discussion 1 01-03-2006 09:31 AM
Digital dash and climate control??? yamathegreat General Hardware Discussion 3 10-31-2005 04:41 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
