Quote: Originally Posted by
a13n0rma1
I'm looking at running an inverter to power my laptop while I'm on site for work.
don't use an inverter unless there is no other option. your laptop runs on low voltage DC (just like your car). and inverter changes the car's 12vdc to 115vac, then your laptop's power brick will change is back down to low voltage DC again. this double inversion/conversion process is very inefficient. it wastes alot of power, so if you're looking to get the most life out of your car battery, then this is NOT the way to go. get a DC-DC power supply (even a cheap auto/air adapter from eBay is better than using an inverter).
a13n0rma1
I was thinking I'd install a voltmeter in the car to be able to tell when the battery is close to being too weak to start the car. Is this the right way to go?
it may help, but it's not going to guarantee the ability to reliably start your car each time.
a13n0rma1
What level am I looking at being unable to start the car?
that depends on the battery rating/age/condition, engine temperature, etc... in general (with a good/new bettery) you can start your car down to around ~10v, but again, it depends on other factors.
a13n0rma1
I may also invest in an ammeter, since that seems to be the more realistic measurement of how much juice is left in a battery.
useless... amperage (current) is how fast electricity is flowing through a given circuit. when you measure amperage, you're only measuring how much juice is being drawn from a specific circuit. unlike voltage, there will be no reading unless something is drawing power (in other words, it cannot be used to gauge the remaining power of your battery)
a13n0rma1
Oh, and I also have a Kinetik HC1400 power cell on the way
I may order another with isolator and all the extra wiring and box to get it to the point of I can sit in the backseat with the laptop overnight music playing and crunching numbers and still go an start the car at sunrise.
that will help, but if you run your radio and laptop all night long you'll still have a dead battery in the morning. that HC power cell (like most car batteries) is designed for high-current 'instant' loads (like amplifiers and engine-starting), it is not designed for low-current sustained loads (like the radio or a laptop).
regular car batteries can provide a lot of power in short bursts, but they also discharge very quickly. crank your engine for a couple minutes and your battery is dead, leave you car sitting for several days and you might have a dead battery just from the clock slowly discharging it. a deep-cycle battery is designed for this type of purpose (slow, sustained load), but is not very good for starting a car.
the bottom line is; a high power battery replacement (and/or a second battery) will help, but will not give you the desired effect you want. if you want to run your laptop all night long then your best best is to simply carry a couple extra batteries with you. it's simply not worth beefing up your car's electrical system just to power a non-installed laptop.
