Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-06-2008, 03:14 PM   #1
ac-dc power supply install question
is there a procedure for installing this ac-dc power supply??
the weird thing is, when the key is still in the ignition, i put the pc on stand by. then when i pull the key out of the ignition, the computer just turn back on. 0.o weirddd
so i was just wondering if theres a special way to set it up. any input would be great!
Zupervinn is offline   Reply With Quote
Old 04-07-2008, 06:45 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
Are you sure you don't mean a DC-DC power supply?
DC is what's in your vehicle.
AC is what's in your home.
And the proper wiring should be in the product manual. If not, posting the make/model of your PSU might be helpful.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-07-2008, 11:49 AM   #3
It might help if you tell us what "this" is referring to. There are LOTS of power supplies, and I don't beleive anyone here has perfected their ESP to work on the Internet to figure out what your referring to.
NotYou is offline   Reply With Quote
Old 04-07-2008, 11:20 PM   #4
sorry guys for being unclear.
this is the power supply i brought
http://cgi.ebay.com/ws/eBayISAPI.dll...m=170208176231
Old 04-07-2008, 11:55 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Ahem. The device you are referring to is a DC-DC power suppy, the M2-ATX.
You don't put the computer into standby because the M2-ATX does that for you automatically.
What you are doing is first manually putting the computer into standby, then turning the ignition off. This causes the M2-ATX to send a pulse to your computer, similar to pressing the power button. In this case, it is telling your computer to turn on.
Don't do anything. Just shut the car off and the computer will shut off by itself. It will start automatically when you turn the car back on - but you need to wait more than a minute before you restart the car due to timing issues on the M2-ATX.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-08-2008, 01:38 AM   #6
ehhh. it doesn't work..last time i left the car without turning it off for 6 hours. that thing killed my battery.
where do u guys have the ignition wire connected to? i have it relayed on my AMP remote wire.
Old 04-08-2008, 02:55 AM   #7
Raw Wave
Rob Withey's Avatar
Did you set up the ABCD jumpers? What do you have them set to?
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 04-08-2008, 06:08 AM   #8
I'm wondering if the OP actually read the M2ATX manual before installing....
My Worklog
Old 04-08-2008, 12:25 PM   #9
Yea I would agree.... I don't understand why you would have the accessory wire connected to the AMP remote turn on...
Wonder at this point what is actually telling the m2-atx to turn 'on' at this point!
Here's a link to the manual incase the OP doesn't have one... http://www.mp3car.com/products/Power...ATX-manual.pdf
Old 04-08-2008, 12:53 PM   #10
wow that helped alot^^ thanks!
but still. im not sure where to connect the ignition wire =x
Old 04-08-2008, 01:45 PM   #11
Raw Wave
Rob Withey's Avatar
Says right there on page 2 of the manual:
Quote:
J3 Ignition (switched battery, positive. Can test by connecting it to Battery +)
Old 04-08-2008, 03:44 PM   #12
ahh lol thanks! =D if i encounter anymore problem i will come and bother u guys some more =D
thanks!!!
Old 04-08-2008, 03:46 PM   #13
thanks!!!
You might also want to try looking in the FAQ's in the Power Supplies forum. Specifically, the M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
Not that your bother us, you just might find an answer quicker then relying on someone posting back.
Opus Solutions 150watt DC to DC Automotive Power Supply millec Classified Archive 3 01-07-2008 08:50 AM
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
AC or DC power supply w/ tablet pc? gutterslide Power Supplies 2 04-07-2004 03:12 AM
Power Supply & TFT LCD question VegaBOND General Hardware Discussion 0 03-23-2000 06:07 PM
dc to dc ATX power supply Kaizer Soze General Hardware Discussion 10 10-21-1999 07:47 PM
