04-06-2008, 10:39 PM
#1
Vehicle: 2003 Honda Accord Coupe EX V6
PLEASE !! I need some help connecting my phone!!
Ok so ive got the RR up n running I have a bluetooth dongle and I have a nokia phone with bluetooth feature ..
my dongle doesn't come with a software so windows automatically installs the driver .. I see the bluetooth icon in the taskbar right click on it and choose add device and get my pc connected with the phone then open RR and open the phone window .. the window opens just fine with all the bottons and dialer .. with the msg "Trying to connect, please wait"
and STAAAYS.....
am not sure what to do!!!
04-07-2008, 03:21 PM
#2
buuump
04-07-2008, 04:07 PM
#3
Vehicle: 2001/Vauxhall/Zafira 1.8 16v
Hi mate,what kind of nokia do you have?
From the "trying to connect" message i guess your using FreeFone so you need to identify what port number your connecting to manually through the bluetooth software and then go into the settings.ini in freefone and edit it with that port number.
You don't need to connect it manually as freefone will make the connection on its own.
P4 2.8 HT, 1GB Ram, 200Gb 3.5 HD, M4-ATX,2 x Silabs USB, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RoadRunner, iGo8,Custom Freedom 2.1
04-07-2008, 05:18 PM
#4
it's my hero again
am I so glad to see you again?!!
well yes am using FreeFone...
how would I identify the port manually ? and by the bluetooth software which one do you mean? is it the one that windows install for the dongle?
04-07-2008, 05:43 PM
#5
ok so I got working the freefone connects to my phone places and recieves calls but it uses the phone mic and speakers and i was under the impression that i would also be able to use the computers mic and speakers
04-08-2008, 01:58 AM
#6
Morning,
Yeah thats a limitation of freefone i'm afraid but i think i know of an app that can help you get round it as long as your nokia and your bt dongle support multiple bt connections at the same time (its has to for it to work)
I'm off to work now but i'll find that app for you and post it later.
EDIT: Here you go = http://www.digital-car.co.uk/forum/s...=audio+gateway
Have a read,that app shoud sort it out for you.
04-08-2008, 04:18 PM
#7
you are OFFICIALLY MY HERO
i got it to work .. had to replace my bluetooth dongle cuz mine doesnt support multi connections
but am glad its finally working (Thanks to you)
04-08-2008, 04:27 PM
#8
I still have one slight problem....
when someone calls me freefone answers automatically
04-08-2008, 04:50 PM
#9
Now that problem is new to me but i'll look into it.
04-09-2008, 03:15 AM
#10
Well there doesn't seem to be an auto answer option in Freefone which leads me to believe that this is something to do with the phone and not the software.
Check the handsfree options on your phone as it sounds to me like part of the handsfree profile.
04-09-2008, 04:24 AM
#11
you might be right but somehow am suspecting the other utility that connect the phone with th computer
when i used the utility to connect to the phone without even running freefone it did the same thing
and i dont think that it has to do with my phone b/c i tried 3 different ones
04-09-2008, 04:50 AM
#12
What happens if you dont start freefone or the audio app and just have your audio gateway connected to the pc manually,when a call comes in does it work correctly or does it still auto answer?
What bt software are you using with your new dongle?
04-09-2008, 03:12 PM
#13
thats a good point
EDIT: so i tried connecting through the BT software and it works fine.. if i open and utility after establishing the connection by the BT software also works fine.. but i open the utility and establish the connection through the utility thats when the autoanswer kicks in
>> > Design & Planning . . . . . . . . . . . . . . . . . . . . 100%
> Software Installation . . . . . . . . . . . . . . . . . . . .98%
> Hardware Installation . . . . . . . . . . . 55%
>>> Overall Progress . . . . . . . . . . . . . . . . .85%
04-09-2008, 03:43 PM
#14
Well in that case you were right the 1st time when you said you suspected the gateway software.
I don't think there's anything more i can do for you other than suggest you post in the developement thread for that app and see if the author can help you troubleshoot it.
04-12-2008, 02:47 PM
#15
I dont mena to hijack this thread, but let me know if this is a bad idea and i will start a new one
I have a similar issue. Once I am in Freefone and connect, i still cannot hear the sound from my speakers, but still do through the actual phone. I downloaded the utility, and after clicking the "poll" button, nothing happens. This is generic bluetooth 2.01 dongle with not even a case to show a manufacturer.
The reason i think it can connect to multiple bluetooth devices, is the fact that the headset profile is active, as well as the DUN profile. I believe they use different ports so what might be the issue here? I would greatly appreciate any help, this is the last piece to the puzzle before my install.
Thanks!
| Thread Tools |
| Display Modes |
Linear Mode
