The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Closed Thread
Thread Tools Display Modes
Old 04-17-2008, 09:57 PM   #31
NotYou's CarPC Specs
Vehicle: 99 Jeep Wrangler / 07 Grand Cherokee
My Photos: (10)
Either you successfully reset you BIOS, or something was corrupted in it. Hard to tell exactly what since the screen is cutting of the message.
Attach your hard drive to Primary master (and make sure the hard drive is set to be master). Then boot up again and go into the Bios.
Go through every page of settings, make sure they are correct. Especially the CPU multiplier and associated settings. Make sure the bus speed is correct as well.
Also check your boot order. Should be set to cdrom, then hard drive.
Save the changes to the BIOS, and let it go through booting again normally. Should be set after that point.
As an aside, you may also want to move you cdrom to Secondary Master. It's not a requirement, but it's the recommended spot for it in a single hard drive / single cdrom drive type of setup.
NotYou is offline
Sponsored Links
Old 04-23-2008, 06:49 PM   #32
My Photos: (0)
ok so i went to auto detect the hdd and no luck at all, i did that in primary in secondary with no luck so its being shipped out for a new one.
ChrisQ0904 is offline
Old 05-19-2008, 06:51 PM   #33
My Photos: (0)
ok the replacement HDD came in and it is not readable either, but when i put a big HDD (on for a big comp) it reads it.... help plz
Old 05-19-2008, 07:07 PM   #34
My Photos: (0)
Ok new problem, i got it to work and i am now installing windows and i hav an issue with the partition thing i go to create one and it doesnt create anything i press c to create and then enter the amount of mb and press enter and then nothing. any ideas or should i start a new thread somewhere else.
Old 05-19-2008, 07:08 PM   #35
My Photos: (0)
looks like ram to me.
try to pull out one of ram chips it you have more than one, if doesnt help, try to switch them.
Xoxol is offline
Old 05-19-2008, 07:28 PM   #36
My Photos: (0)
I only have one ram chip and i pulled it out and put it back in still the same thing. Think i need a new one? If so what would be the best type?
Old 05-19-2008, 08:00 PM   #37
My Photos: (0)
got a new ram stick and still cant create a partition
Old 05-19-2008, 08:24 PM   #38
My Photos: (0)
can a mod close this thread, im going to create a new one with a better title so i can get more help.
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
Need assistance improving boot time - Windows Xp - 12s hidddenh Operating System Optimization 14 02-12-2008 04:15 AM
Argh! Two Problems: USB HD wont read on boot, only after, and CF prevents boot also.. wardemon666 General Hardware Discussion 10 04-17-2006 05:23 PM
Windows XP won't boot up anymore!!!! Luderboy Newbie 3 09-03-2005 06:03 PM
EPIA M Network Boot Disk slarty Software & Software Development 0 04-10-2004 10:08 AM
Enabling/Disabling Setup via boot disk? gizmos Software & Software Development 0 07-14-2000 10:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
