The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-17-2008, 11:04 AM   #1
My Photos: (0)
using laptop HD w/barebones system
if i picked up a barebones system would i be able to use my compaq laptop Hard drive with it? I am getting pretty ****ed off because i try and wire up a button to turn the laptop on and off and it keeps breaking off, so i am looking at other routes.
tacobandit is offline   Reply With Quote
Sponsored Links
Old 04-17-2008, 11:48 AM   #2
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
as long as your "barebones system" uses the same HDD connector then it should plug right in. if it uses a different interface then you'll need an adapter or controller card, but you can still use it.
NOTE: you can't simply swap the HDD and use it as-is. your current windows installation matches your laptop hardware and will not work properly with your new "barebones system". after you connect the HDD in your new system you will need to format the HDD and install a clean (non-OEM) OS onto it so that it sets itself up for your new hardware (make sure you backup any important data first).
FusionFanatic is offline   Reply With Quote
Old 04-17-2008, 12:29 PM   #3
Grrrmachine's CarPC Specs
Grrrmachine's Avatar
Vehicle: Audi 80 Coupe 1.8 1982
My Photos: (8)
Odds are your laptop is an old 2.5" IDE drive. Even if your barebones motherboard is IDE (not SATA) you'll still need a converter, but they're a matter of pennies from eBay.
Grrrmachine is offline   Reply With Quote
Old 04-17-2008, 01:20 PM   #4
My Photos: (0)
how would i format it?
Old 04-17-2008, 01:40 PM   #5
the415's CarPC Specs
the415's Avatar
Vehicle: 2005 Mazda 3
My Photos: (0)
i use one of these for my 2 2.5" hard drives in a 3.5" bay.
2005 Mazda 3 Hatch
TWM | Cosworth | HKS | AutoExe | Rev | Kumho | Tein | AWR | EBC
Carputer Specs: 98% Completed
Dell Optiplex GX270
P4 2.6GHz
120GB 2.5" HDD
512MB RAM
DS-ATX
BU-353 GPS
XM Direct Universal Tuner
7" Xenarc 700TSV
the415 is offline   Reply With Quote
Old 04-17-2008, 02:37 PM   #6
My Photos: (0)
Okay so what would be the process to get it working? How would i format it? Would it format when i installed an OS? I only know the basics when it comes to computers so any information would be great.
Old 04-17-2008, 02:41 PM   #7
the415's Avatar
My Photos: (0)
yeah toss in the os and go from there.
2005 Mazda 3 Hatch
Dell Optiplex GX270
P4 2.6GHz
120GB 2.5" HDD
512MB RAM
DS-ATX
BU-353 GPS
7" Xenarc 700TSV
Old 04-17-2008, 03:48 PM   #8
My Photos: (8)
Make sure you have a bootable OS install disc BEFORE you wipe the drive out of the laptop and mess around with it, otherwise you'll have two dead computers!
Old 04-17-2008, 04:43 PM   #9
My Photos: (0)
Okay i have been looking at getting Linux, since i dont want to spend another 100 bucks on getting XP, does anyone know anything about it? Will it be compatible with my lilliput and my gps software? Do i need a special front end or can i DL any? I looked thru the linux forum and theres not really a FAQ.
Old 04-17-2008, 10:25 PM   #10
golfguy's CarPC Specs
golfguy's Avatar
Vehicle: 2007 Mazdaspeed 6
My Photos: (0)
If you don't yet know how to format a disk for Windows, I wouldn't recommend you make the leap to Linux. Many aspects of Linux are not very user friendly and can require some knowledge of the system to get properly configured. Stick with Windows and build up some experience before you try something like Linux.
Any day is a good day for golf.
Mazdaspeed6 Carputer Progress:
(Check Speedy's Install)
Purchase [*****] 100%
Design [*****] 100%
Install [*****] 99% (is it ever finished?)
golfguy is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
WTB: laptop dvd-rom or dvd burner and laptop hd macmini Classified Archive 0 09-06-2005 12:11 PM
Not using laptop anymore.. Need Epia system FAST! Audamn Newbie 1 02-03-2004 07:07 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
