The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-18-2008, 11:25 AM   #1
My Photos: (0)
FAQ Crashes
I was wondering what are the most common causes for CarPCs crashing?
How do I avoid those pitfalls? I was thinking that the most common element would be hard-drives so I'm thinking about using flash drives so there's very few moving parts.
MP3 Searches:
crash
crashes
crashing
dasickis is offline   Reply With Quote
Sponsored Links
Old 04-18-2008, 11:43 AM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
MP3 Searches:
crash
crashes
crashing
HDs are very robust.
Your crashes will probably be from software.
Old 04-18-2008, 02:23 PM   #3
brucedog's CarPC Specs
brucedog's Avatar
Vehicle: 2000 Saturn LW Wagon
My Photos: (22)
Here is a specific bugaboo that might be applied generally...
When using the Voom carpc enclosure, the ribbon cables for the HD and CdRom drive must slide in/out when the blox is slid open/shut. There is verrry little spare room in the case. In addition, the cables often bear against the memory card, gradually warping it.
The carpc crashes. There are other enclosures with similar space issues.
Other issues:
I spoke with a man several years ago who was assigned to give a few of us a NASA-certified soldering course. He said, in a word, that "connectors" were the biggest problem that NASA had as that time. Vibration, crimps that come loose, pressure exerted ON connectors or BY connectors...can cause electronic failures and intermittent (the worst!!) operations.
I have not been impressed at the quality of MANY of the Chinese-made junk mini-itx and micro boards that get used in carpc's. The solder joints and connectors often just "look" cheap. How do I know? Hang around electronics long enough, and you will learn how to tell the decent from the crappy - it's subtlle sometimes, but true...if it looks cheap, then it probably is.
I wouldn't be surprised if carpc crashes are also often caused by pitfalls that cause other mobile electronics to crash:
>poor power connections; small arcs and glitches that upset the delicate electronics
>heat - fans are nice, but if all they do is circulate REALLY hot air, they do no good
>connectors (as above)
>demanding carpc user who wants to open too many apps, too fast - take it slow and be reasonable...
>hardware / software compatibility issues - install ONE piece of new eqpt at a time, then play with it for awhile to be sure it works
>krappy mobos (as above)
Best of luck and blessings!
Happy CarPC'ing!
brucedog is offline   Reply With Quote
Old 04-18-2008, 11:51 PM   #4
pRoFiT's CarPC Specs
pRoFiT's Avatar
Vehicle: 91/chevy/S-10
My Photos: (2)
I think crashing in general is bad. I personally dont let my carpc drive anymore.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline   Reply With Quote
Old 04-21-2008, 01:23 PM   #5
My Photos: (0)
Thanks for the great responses. I know that most of the crashes people face are with software but I wanted to know in terms of hardware. I'll be putting the software under some brutal tests.
Also, I wanted to know how to properly test that the hardware will last for a few years (at least 5)
What suppliers have you had bad experiences with or what search terms should I put in mp3car.com?
Also, does touchscreen have a higher/same/lower failure rate as non-touchscreens?
Old 04-23-2008, 10:16 PM   #6
Super Duper Moderator
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (14)
Usage.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
streetdeck crashes when i click on 'Select this Artist' bembowe StreetDeck Bug Reports 3 03-20-2007 11:44 AM
Crashes on Search dannydxd StreetDeck 1 12-13-2006 07:15 AM
Skin Editor v0.3.019 Glitch - Crashes smeg RR Skins 2 03-13-2006 01:48 AM
MediaEngine crashes on me :( jnusaira Media Engine 9 04-07-2004 02:56 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
