The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-25-2008, 12:54 AM   #1
My Photos: (0)
VW CarPC build questions
Going to put a CARPC in my 2003 VW Bora (Jetta). Just curious are there any wiring issues or electrical I should worry about in the instance of no longer using the harness from my car to my Monsoon head unit anymore? Also what do you recommend for a sound card for the best sound quality under 100$. Thanks!
VeeDubBORA is offline   Reply With Quote
Sponsored Links
Old 04-25-2008, 12:56 PM   #2
Beehphy's CarPC Specs
Beehphy's Avatar
My Photos: (0)
Here is a thread talking about setting up a aftermarket deck in an '02. From what I could tell you can continue to use the monsoon Amp to power the speakers.
As for sound:
Sound Blaster Audigy 2 NX USB 24Bit External Sound Card
Beehphy is offline   Reply With Quote
Old 04-25-2008, 11:04 PM   #3
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Read this.
I put an aftermarket Sony Xplode in my VW Beetle (2001) without knowing any of this stuff and remarkably, it worked with no problem, so YMMV. If it doesn't, that thread will help you out.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-27-2008, 02:08 AM   #4
My Photos: (0)
As for sound:
No I will be using a JL Audio 300/4 amp as the amp. So I just wanna know if the head unit controls anything in the car electronically I should know of?
I will be replacing speakers as well in case anyone didn't catch on that I'd be replacing the entire system. I'm gonna do this right. Two JL XR650CSi's and two JL XR650CXi's and then a stealth box 500/1 for the sub/sub amp
Old 04-27-2008, 08:19 PM   #5
Bugbyte's Avatar
My Photos: (19)
Well, the headunit signals the monsoon system to turn on. If you remove it, it may not turn on.
Old 04-27-2008, 08:28 PM   #6
My Photos: (0)
if you are no longer using any stock components, then its does not matter if it is a vw, or a Honda, a car audio install requires the same steps no mater what car it is.
it can only get more interesting if you start using stock components.
VW GTI 20th AE BMP
trititan is offline   Reply With Quote
Old 04-27-2008, 11:21 PM   #7
My Photos: (0)
Okay that's all I wanted to know for that, I've just noticed with some cars that removing the stock radio can affect other electronic components and VW has some strange wiring sometimes so I wanted to be 100% sure.
Sponsored Links
vB code is On
Trackbacks are Off
99 VW Passat, Smartphone carpc hp 6515 spybld Show off your project 0 07-08-2007 11:37 PM
DIY: I want to build my own components. Questions. nobb Car Audio 4 04-22-2007 10:40 AM
CarPC install on 96 Jeep Cherokee - Questions.. briderx Newbie 6 03-19-2007 03:36 PM
A Few questions about Digital Sound with a Carpc ddotderek Car Audio 39 11-26-2006 08:33 AM
2004 VW New Beetle CarPC chomo Worklogs 16 11-24-2006 01:40 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
