The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-25-2008, 11:25 AM   #1
My Photos: (0)
**Newb Install** G35 Monitor Power
This is a definite newb question and was probably asked already but i need to know if there is any other way to power a lilliput 7" TSV screen. I am thinking of buying one but dont want to have the wires poking out of the center console just to plug into the cigarette lighter. I heard people say that they have powered their monitors through the opus power supply can someone give me an insight on how that is done.
jeffreymagloire is offline   Reply With Quote
Sponsored Links
Old 04-25-2008, 11:33 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
12v fdrom a HDD power connector.
Yellow = 12v.
Black = Ground.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-25-2008, 08:35 PM   #3
lucegunz's CarPC Specs
My Photos: (0)
Yellow = 12v.
Black = Ground.
Does that work for xenarcs too and can I use m2 power supply too the same way?
lucegunz is offline   Reply With Quote
Old 04-29-2008, 05:37 AM   #4
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (226)
It works for any monitor that uses 12V power. Yes you can use a M2-ATX in the same way. Although me having a diffrent setup, I would simply use the existing regulator and fuse that your screen came with and use a relay to switch it on and off, that way the screen comes on right away, which is good if you ever plan to use a backup cam.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [98%]
INTERIOR MODS [35%]
BUDGET [220%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 04-29-2008, 07:07 AM   #5
My Photos: (26)
IT works for any device that draws 12v power, so long as it doesn't overload the M2.
Honestly, if you are using a Xenarc, it has built-in regulation, so you are safe to wire the monitor directly to the vehicle's ACC line.
My Worklog
Old 04-29-2008, 11:41 AM   #6
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
can i connect a lilliput 7" straight into my cars acc line?
Unphased A New and upcoming site for VW owners.
EaRNi is offline   Reply With Quote
Old 04-29-2008, 12:03 PM   #7
HiJackZX1's Avatar
My Photos: (226)
Wait, not to try to think that i know what Im talking about, but when you say straight to the ACC line, you mean through a relay? From what I understand it is bad to run anything through the ACC line. It was made to send signals, not power devices. So you have to use a relay and connect the constant power to that. Then the ACC activates the relay to power the screen from constant.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [98%]
INTERIOR MODS [35%]
BUDGET [220%]
HiJackZX1 Work Log
Old 05-01-2008, 12:15 AM   #8
My Photos: (0)
what about powering the monitor through whatever the radio was getting powered by?
Old 05-01-2008, 12:18 AM   #9
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
yes that is correct
Powering just the monitor through the stock radio harness is ok, as it will draw comparable current.
Powering the computer through the radio harness is NOT ok.
Old 05-01-2008, 05:46 AM   #10
HiJackZX1's Avatar
My Photos: (226)
Like Toaster said, that will work..... What screen is it? Make sure it had built in power regulation, because the radio harness power is unregulated and will destroy your screen over time.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [98%]
INTERIOR MODS [35%]
BUDGET [220%]
HiJackZX1 Work Log
Sponsored Links
vB code is On
Trackbacks are Off
Planning on an 08 G35 aceball Newbie 1 01-30-2008 09:08 AM
Infiniti G35 700TSV for an '07 G35 Ructus LCD/Display 0 08-14-2007 08:37 PM
2003 G35 Sedan project villybhakta Newbie 21 05-10-2007 03:00 PM
Need help with manuals for 04 G35. st_abbott36 Newbie 3 01-11-2007 03:10 PM
fs: infinity g35 has computer playstation subs vipergda Classified Archive 6 04-06-2005 02:33 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
