Quote: Originally Posted by
DuoMaxwell
currently it runs off of my laptop
are you planning to use that laptop as your permanent carPC or will you be replacing it with something else down the road? what are you using to power the laptop?
DuoMaxwell
This LCD screen runs off of 12V DC so I shouldn't have any issue hooking it up straight to the battery
if you're going to power the screen off the car battery, then make sure the screen has some sort of power regulation to deal with the fluctuating car voltage. if the screen came with a cig lighter plug with an in-line regulator then make sure you use it. if it's just a plain wire then open up the cig lighter plug to make sure there are no electronics inside it before you hardwire it in.
DuoMaxwell
I hooked the wiring harness up and something weird happened. WIth the key out of the ignition nothing had power....no power door locks etc...with the key in the ignition set to on everything worked fine. I was freaking out thinking my body control module was cooked.....but then I went under the hood and found out (after many hours of beign worried) that it was just a blown 10A fuse
how did you blow the fuse? did you short-circuit the wires, or did you overload the circuit? hopefully you're not trying to directly power anything extra off of those stock amp wires.
DuoMaxwell
whenever I tried hooking up my laptop to the Metra harness I got no sound which is rather weird. I'll poke around tomorrow and see if there's another blown fuse....but is there any way the head unit communicates with the amp in some sort of way other than sending sound? Or maybe the wiring harness I purchased is no good?
well something has to tell the amp to turn on/off. the switched 12v wire may come from the head unit, and now that you've removed it the switched 12v wire may not be powered anymore. if this is the case then you'll have to connect it up to an ACC line so it turns on/off automatically.
did the wire harness come pre-wired or did you hook it up? do you know the pin-out for the harness/connector? are you sure the stock amp accepts low-level inputs? sometimes stock amps have speaker-level inputs, if this is the case then your laptop's audio-output will not be a powerful enough input for your stock amp.
