The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-28-2008, 12:36 AM   #1
My Photos: (0)
Case and Mounting help
Hi all,
In the middle of collecting parts etc for my first carpc. I was thinking of mounting the case on the side or back of my sub box. Sub box is 3/4" mdf, is this going to wreck my sata hdd? Would it matter if the box had sound deading?
I can also make the box so that one wall of the sub box sticks out on either side like _[]_ would mounting on the stick outs be any better, it would prob be one soild bit of wood
On the subject of cases can anyone point me towards a case that will take a pci sound card, smaller the better.
Thanks in advance
cletusb is offline   Reply With Quote
Sponsored Links
Old 04-28-2008, 11:02 AM   #2
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
why would you want to mount your carPC to your sub box?
I don't think the sub itself would "wreck" your HDD, but having your carPC mounted to a 'loose' sub box (the box will bounce around when you hits bumps) might damage it. another issue would be theft. if some d****bag breaks into your trunk/boot and steals your subs then you automatically lose your carPC with it. I'm not saying they wouldn't steal it anyways, but there's no point in making it easier for them.
it would be better to mount your carPC to the car itself. it can still be in the trunk/boot, just not on the sub box itself. many people have their carPCs near/next to subwoofers. I ran mine like that for months without a problem. the HDD I used was about 6 years old, and it still works good to this day. I haven't read of any HDD failures as a direct result of being too close to a subwoofer.
mounting your carPC in the trunk/boot works fine, many members here have their systems mounted there. it's a bit more of a pain because you need to run VGA and USB extension cables, as well as extra long wiring for power, ACC, audio, etc. I'm not telling you not to mount it there, but I would suggest looking at other locations as well, and weigh the pros/cons of each location carefully before you start building everything.
as far as cases are concerned, we can't recommend a case until we know what components you will be using (motherboard, HDD (2.5" or 3.5"), PSU, etc).
FusionFanatic is offline   Reply With Quote
Old 04-28-2008, 01:21 PM   #3
My Photos: (0)
Subwoofer box = Vibrations.
Depending on how well your box is built (I'm guessing your's is pre-fab), the sides of the box actually flex.
This will reduce the life of your PC much faster.
So unless you are doubling up that 3/4" MDF and bracing the crap out of it, mount it to the vehicle.
ArcaneDreams is offline   Reply With Quote
Old 04-28-2008, 01:26 PM   #4
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
if a sub box is built into the car, bolted down and doesnt move a millimetre would it be a good idea to mount a car pc next to it, not onto the side of the box but onto the same surface the box is mounted to.?
Unphased A New and upcoming site for VW owners.
EaRNi is offline   Reply With Quote
Old 04-28-2008, 06:11 PM   #5
My Photos: (0)
Hi all thx for the comments so far. Re the sub box, I want to mount it on the sub box as I am aiming for a stealth install and if I mount the case on the sub box it can be hidden by the false wall shown in the 1st post. Its a custom job built for my car (2006 Mazda6 MPS / Speed) so it will be bolted down tight and be made of at least 3/4" MDF and possibly a little fiberglass). Is being made by myself and a buddy of mine who is a cabinet maker so we can brace and seal the hell out of it
For the case my ideal pc components at the moment are
M4-Atx PSU
Intel D201GLY2A Motherboard
1g DDR2 677 Ram
Sata 2.5" around 120g
Creative Sound Blaster X-Fi Xtreme Audio
USB Devices for Internet, OBDII, DVD, GPS etc
Thanks for the continuing help
Sponsored Links
vB code is On
Trackbacks are Off
Hardware Review: Mobile Computing Solutions Mini-ITX case Dingo509 The Review Palace 10 12-06-2007 07:25 AM
mounting case inside car johnnm Newbie 9 03-13-2006 11:53 AM
Mounting hardware in a custom case. Amateur night. Bailey Fabrication 5 05-09-2005 11:09 PM
double din case with mounting points for the liliput and the xenarc rotarypower101 LCD/Display 5 03-31-2005 02:07 PM
Mounting the case TheFly General Hardware Discussion 8 05-05-2002 03:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
